stumbling at idle
Old Mar 3, 2008 | 02:28 PM
831chevyman's Avatar
Car: 67 Camaro/91 Camaro
Engine: 350/3.1 v6
Transmission: M22/stock
Axle/Gears: 3.73 GM 12 Bolt/stock
stumbling at idle
i have a 91 camaro with a 3.1 that i just purchased... im having a problem with the idle on the car... at stop lights it seems to stumble and drop pretty low almost like it wants to die... and at times when i go to take off it hesitates at the beginning but after that it is fine... just did a tune up on it thinking that was it but it only helped out a bit... any ideas on what it could be?
Old Mar 3, 2008 | 09:10 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: stumbling at idle
You need to read the thread.."Ditch your stock Injectors" your having the common complaint from V6 owners.
Old Mar 4, 2008 | 12:13 AM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
could be a vac leak somewhere
Old Mar 4, 2008 | 07:58 PM
Engine: 350/3.1 v6
thanks for the info guys... im checking out the info on the injectors and it sounds like what i got but i was also looking around the back at the vac lines and it looks like the person i bought it from used electrical tape at one of the t's and they look pretty worn out to so ill try that first before changing out the injectors... thanks
Old Mar 8, 2008 | 06:37 PM
TheTech91RS's Avatar
Car: 83 z28
Engine: 305 v8 5.0L
Transmission: T5 5SPD
I've got a little bit of a different problem, maybe you guys have some advice on... 3.1L v6, 5SPD.
It starts up, sometimes will idle about 500rpm's high, and it will randomly JUMP to about 2500rpm.... It just high idles, i reset the battery thinking maybe one of the censors went oddballed or something, any ideas what could be causing this idle issue? If you know please reply asap.. as im trying to get it fixed as i type this haha.
Old Mar 9, 2008 | 09:57 PM
jstrdn90rs's Avatar
I think you will need to check some things first and then post them cause we will need some more info,to give you some of our ideas/feedback.For example check codes(engine light on?)fuel pressure,and charging system.
Grant2k
Apr 4, 2016 08:21 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
earlpote
Sep 12, 2015 11:55 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
