trans stuff
Old Mar 11, 2008 | 06:22 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
trans stuff
i have a lot of 'woble' at my gear stick (t5) ive looked at the trans mount but it looks ok?? could it still need replacing to steady everything? its just a rubber bung in a pot really aint it, should i try a poly one instead?
ive looked at the trans forum but just wondered on your experiences as felow v6 owners
thanks ant
Old Mar 11, 2008 | 07:20 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: trans stuff
I personally like the poly trans mounts, others complain about vibrations. I can take it!
A new mount is good, but slop in the stick is not related to that. Our shifters are the rail type and they have a ball formed on the end inside the transmission. That ball wears down a lot and allows lots of travel inside the rail you are in. A new shifter will tighten it up some.
Old Mar 12, 2008 | 01:32 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: trans stuff
ahhh cheers mate, dosnt look like a problem then ill sort it later
lt1z350
Sep 29, 2015 01:50 PM
lt1z350
Aug 28, 2015 05:57 AM
nuggie
Aug 25, 2015 01:27 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
