external balance to internal balance
Old Mar 25, 2008 | 11:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
So my 86 T5 bird is external balance.
If I get EricW internal balanced engine all I gotta do is get a netural balanced flywheel for the stick???
Or knock the weights off my external balance one???
[I assume they are all netural balanced, then they add weights in the proper spots?]
Old Mar 25, 2008 | 11:54 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: external balance to internal balance
Id assume also that the front balancer pulley is fine that on the engine???
It was in a fiero he said.
http://i279.photobucket.com/albums/k...s/DCP_0802.jpg
http://i279.photobucket.com/albums/k...s/DCP_0803.jpg
Old Mar 25, 2008 | 08:56 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Forget the Fiero engine.
The starter is on the wrong side and there is not enough block material on the proper side to drill and tap for the starter.
You can use the internals on/in yoru current block however.
But to answer the flywheel question, you need to get one from an internally balanced F-body, S-series should work as well. You can't simply "knock off" the weight on a flywheel, it's cast into the flywheel itself.
On a flexplate, the weight is welded on.
Old Mar 27, 2008 | 11:33 PM
Drew's Avatar
The surface of the block isn't machined smooth, but you can usually just have the other side of the block drilled and tapped for the starter. It's kind of a hackjob, but it's worked for plenty of people. Machine shop charged my buddy $30 to drill and tap a 3.1 Firebird block that ended up in a 86.5 Fiero GT.
Old Mar 27, 2008 | 11:51 PM
Yeah you can convert a logitudal block to use a transverse starter location, but you can't go the other way. The tranny ear on the other side is cut off to clear the transverse transmission, and is also missing an extra bit of material for the inside bolt location.
Old Mar 27, 2008 | 11:56 PM
Drew's Avatar
The 3.1 block I threw away looked like it had enough meat to drill and tap for the starter, but I wasn't happy with how it was going to come out. I ended up throwing a fully machined, overbored, 3.1 block in the car when I crushed it. I wouldn't recommend doing it either way. Like I said, it's a hackjob.
Old Mar 30, 2008 | 03:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Guess Im gonna hafta wait, no rush on making the deal then.
I got a new trans on a truck heading here for my V8 car.
I need to get it all done right before I spend bunch more on the Bird.
Just I really don't like the lower oil PSI, I got 20 or less, had a constant 40+ for 7+ years even with over 200K but one oil change using Rotella cleaned to well.
lucas, motor honey, thick oil don't help.
Dunno if the trouble of just putting in a new oil pump would help. Since it still runs strong id assume the pump is just worn but who knows. Might of been oil resiude also filling up slack in bearings..........
But it just sucks as I don't feel comfy driving it as is and gas is so high........
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
