Idle qestions.
Old Mar 27, 2008 | 08:28 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Idle qestions.
Ok i have just got my motor running. My problem is that when i give it some gas it starts to sputer and tryes to back frire. dont know what causes that. Any help.
Old Mar 28, 2008 | 12:38 AM
Drew's Avatar
Re: Idle qestions.
I'd start by verifying the firing order.
Old Mar 28, 2008 | 05:45 AM
83camaro86's Avatar
Axle/Gears: stock
Re: Idle qestions.
I have checkd firing order two to three times. The order is 123456 right. ITs for a 2.8. It seems to idle fine. But when you try and give it gas is when it dont want to take none and sputers and trys to back fire thurght the TB. I think i have all the wires hucked back up not sure it that would do it or not. Thanks for any help
Old Mar 28, 2008 | 11:23 PM
Drew's Avatar
Re: Idle qestions.
When did the problem start? Has it ever ran properly?
Old Mar 29, 2008 | 06:44 AM
83camaro86's Avatar
Axle/Gears: stock
Re: Idle qestions.
I dont know. I bought the car with out a motor in it. I got a motor from a jy. I have just put it in and all. I am not sure if i have some of the wiring worng or the vacume wrong. But i a guess the car ran fine until the old motor was blown. The motor form the jy was out of a running car. If any of this hleps
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
