tool for brakes???
Old Apr 2, 2008 | 04:06 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
tool for brakes???
I dont have any awls or the special tool used to get the weel cylinder off and my screw drivers a bit to big. are there any other tools that can help me get the cylinder off? Should i just go get a smaller screw driver?
Thanks guys
Old Apr 2, 2008 | 04:35 PM
paul84z's Avatar
Car: 1984 z28--1987 LT
Engine: 305HO
Transmission: turbo350
Re: tool for brakes???
i usually heat them up with a torch and pop them off. as for installing your right about the tool mine cost about 85.00 through snap-on. if im at home i usually grt 2 medium size flat heads ind put 1 on each side and work it back on but.....if your working on a 92 should'nt they be bolted on? most are either female torx bits or bolts
Old Apr 2, 2008 | 08:08 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Drums I assume. If you are lucky you could be able to pull them off by hand with a little force and wiggling.
Old Apr 3, 2008 | 04:01 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
I use two small flat head screwdrivers. Each one less than about 1/8 of an inch wide.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
mrdevontay
Sep 2, 2015 08:04 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
