Help with timming.
Old Apr 6, 2008 | 09:17 AM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Help with timming.
Hey I have just got my motor back in the car. I lined the crank spocket dot up with the cam spocket dot. I then put the rest to TDC but in found out i need to be at 10BTD. What will I need to do to fix this. Will I need to mess with the timming chain or just with the Dizzy and wires fix it. THanks for the hlep and time
Old Apr 6, 2008 | 10:26 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Help with timming.
Keep going. The two dots are for cam timing. Once that set, it'll never change until your chain stretches/slips a tooth. The 10* is for ignition timing, which is set by turning the distributor.
Old Apr 6, 2008 | 06:07 PM
83camaro86's Avatar
Axle/Gears: stock
thanks thats is what I thought
project89
Oct 31, 2010 12:44 AM
Fast Toyz
Jun 25, 2010 05:32 PM
Ben92
Sep 5, 2008 09:36 PM
L69HAWK
Jun 19, 2008 02:58 PM
FASTIROC
Sep 11, 2007 05:57 PM
