Smog delete bracket with pully
Old Apr 9, 2008 | 11:28 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I ahve two smog delete brackets with pully's for a v6 car.
Asking 25.00 shipped each
Old Apr 9, 2008 | 12:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Smog delete bracket with pully
Are you sure these are v6 only? As Id love to put one on this v8.
Old Apr 9, 2008 | 12:37 PM
kurfbird's Avatar
Yes I have only seen this type of v6 motors. the V8 are a bigger pully
Old Apr 10, 2008 | 04:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
when i ditched my AIR pump, i didnt need a delete pulley, mine had an optional belt w/o AIR. might wanna check if you even need a pulley. then again mine was an 88, so things may have changed. id call the parts store and see what ur options are for belts. if the alternator is in the same place as it is on mine, you shouldnt have any problems just running a shorter belt, since it comes from the alt down to the crank. food for thought.....
Old Apr 10, 2008 | 05:50 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I have that delete pulley and have an 89. When I went to the parts store to get a new belt there are different belts for w/ air, w/o air delete pulley, and w/ the delete pulley.
Old Apr 10, 2008 | 07:41 PM
drdave88's Avatar
Engine: 6.0L
[QUOTE=2.8RS;3713065]I have that delete pulley and have an 89. When I went to the parts store to get a new belt there are different belts for w/ air, w/o air delete pulley, and w/ the delete pulley.[/QUOTE
when you say (with air) do you mean "with A/C" or "with AIR". there is a big difference when saying "air". im not trying to confuse, just wanna clarify to all of us.
Old Apr 10, 2008 | 07:42 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
[quote=drdave88;3713179]
I mean AIR. I have the belt with the delete pulley and for some weird reason it was $20 more than the other two belt options.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
bryaniskoo
Oct 1, 2015 03:18 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
