What is this by-passing?
Old Apr 20, 2008 | 02:47 PM
Jammin'Trey's Avatar
Here are some pics off the drivers side of the motor (MPFi 2.8L). The bypass was done with a screw and a clamp between a hose and a pipe.
What is this bypassing? Is it bad ?? The car runs and drives great I haven't noticed anything bad.
Attached Thumbnails What is this by-passing?-hpim1668jw7.jpg   What is this by-passing?-hpim1670hq9.jpg   What is this by-passing?-hpim1671ez2.jpg
Old Apr 20, 2008 | 02:52 PM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
Re: What is this by-passing?
That is to the smog pump. Won't hurt anything. That is mostly for emissions. Just sends fresh air into the exhaust.
Old Apr 20, 2008 | 02:57 PM
Ok, am I getting any more performace because of this? Why would you block this off.
Old Apr 20, 2008 | 03:03 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
There is actually no reason to block it off unless you are removing the air injection system completly. Is the air pump still there?
If the air pump has been removed and you do not actually have any pully there, then you MAY have picked up 1/16th of 1 pony.
There is no reason to remove it unless you have installed the pacesetter headers that don't support the air injection system.
Old Apr 20, 2008 | 08:58 PM
yee haw
taman86
Feb 22, 2004 06:00 AM
stuart
Sep 30, 2003 09:17 PM
ZZ28ZZ
Mar 14, 2003 10:10 PM
Four12'sCamaro
Mar 1, 2002 03:17 AM
