Good exhasut gaskets that won't blow out
Old Apr 23, 2008 | 03:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I am tired of replcing my exhaust gaksets every couple of months. I have headers and have tried the Felpro gaskets, the one for Fieros, and the gakets from NAPA. The felpro ones last about a couple of months, same with the fiero gaskets. I just put the gaksets from napa in and they blew out bad when I started the car up. Bolts are always checked and tightened down every few days when I first put them in then about once a week. I just put some from Felpro in and there is already a few leaks. I just want some gaskets that won't blow out every month with just regular driving. Its pissing me off pretty bad, its just so frustrating to replace the same part over and over.
Old Apr 23, 2008 | 03:46 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: Good exhasut gaskets that won't blow out
Check out these gaskets...FelPro MS93692
I got these for my build. They are for the Gen 2 heads, but can fit if you work the bolt holes. They have 2 layers of metal sandwiching another gasket layer, plus larger ports.
The good ones on top. Doubtful that they will blow out.
Old Apr 23, 2008 | 03:49 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Where did you get them?
Old Apr 23, 2008 | 03:58 PM
grimmcs's Avatar
Car: 91 Camaro
I got mine at RockAuto, you can also get them at Summit
Old Apr 23, 2008 | 04:30 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I just put Felpro ones in again. The car is alot quieter now. What are the odds of 5 out of 6 ports blowing out in less than a day? Tee gaskets were burned to a crisp. I'll pick some of those up one day. Thanks.
Old Apr 23, 2008 | 04:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
coat both sides well with 100% clear silicone and let it sit over night before driving.
Just put in a new trans and did dual exhaust on my Buick.
They don't have exhaust donuts, its a steel to steel flange.
Its what I use to make them leak tight, works very well.
They were sealed up that way before when I just had a single also so I have long testing, its works well.
Old Apr 23, 2008 | 06:41 PM
firstfirebird's Avatar
I'll say it again...
Why doesn't anybody listen to me when it comes to header gaskets?!?!?! Use gaskets from a 1971 VW Beetle, they are a perfect fit, reusable and are the same style as the 3x00 gaskets.
http://www.fullthrottlev6.com/forums...2&postcount=15
http://www.fullthrottlev6.com/forums...7&postcount=12
Old Apr 23, 2008 | 06:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Them are the ones dean suggested. I never got ahold of any.
Also, if you keep having the same problem. Make sure the surfaces are clean and even. The stock paper ones blew out quicker then crap. But I put the metal felpro on. No problems other then the occasional loose bolt.
Old Apr 23, 2008 | 06:56 PM
That's where I got the idea He always manages to get banned, but has good info.
Old Apr 23, 2008 | 08:20 PM
Dale's Avatar
Engine: 350 S-TPI
Agree. Hes given me tons of advice via email. Problem is I dont have the money to do half of what he suggest
Old Apr 23, 2008 | 08:58 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I would like to know what in the world the person was doing when they realized it was a direct fit.
I guess it's kind of like wondering what the first man to drink a cow's milk was thinking...
Old Apr 24, 2008 | 05:56 AM
Dale's Avatar
Engine: 350 S-TPI
Dean use to have a Karmanghia (sp?). Had them laying around his shop IIRC.
Old Apr 24, 2008 | 06:19 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
I have a good set or mr. gasket copper gaskets and they have held up for the 2+ months that my headers have been on the car with no leeks.
Old Apr 24, 2008 | 06:51 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I would like to try some copper gaskets, the problem is that I think nobody makes them for our cars.
Old Apr 24, 2008 | 01:30 PM
Engine: Vortec 357
they make them for 305-350's but im not shure about V6's. Ill see what i can find for you unless someone on here already knows where to get some.
Old Apr 24, 2008 | 02:34 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ive always used metal felpro with no probs. any chance the flanges are warped ??? might be worth taking them out and skimming them ? just an idea
Old Apr 24, 2008 | 03:58 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I think they may be. I got some LTs that I am putting in with the new motor so I won't bother taking them out and checking them out.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
justin57
Aug 20, 2015 07:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
