Changing rear cam cover seal!
Old Apr 23, 2008 | 06:23 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Is there a way to change the rear cam cover seal without dropping the tranny? I changed mines a few months ago but now its leaking again. This time I will be using permatext on it when I put it back on.
Old Apr 24, 2008 | 12:51 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Axle/Gears: ?
Re: Changing rear cam cover seal!
sure pull the engine.. leave tranny in the car
Old Apr 24, 2008 | 02:36 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
is it really leaking that bad ?
Old Apr 24, 2008 | 10:31 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Make sure it's the cam cover seal and not the distributor o-ring first. You'll be kicking yourself if you don't check it before you pull it all apart.
Also, while you're there, I'd suggest replacing the rear main seal.
Old Apr 25, 2008 | 12:38 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
true, LIM aswell
Old Apr 25, 2008 | 11:20 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
You are so right about that! I read that you guys say that all the time and I never thought to look. Will be doing that this weekend. I hope thats all it is.
Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
Rustyweb7
Aug 9, 2015 03:05 AM
