MAN AM I GONNA HAVE A TREAT FOR YOU GUYS
Re: MAN AM I GONNA HAVE A TREAT FOR YOU GUYS
tommmorow were going back im having an 11 and 14 psi wastegate springs sent to me for tom,first pass will be at 6 psi on the slicks to dbl check the tune,second pass will be a half track run on 11 psi, and if all goes well 3rd run will be a full pass on 11 psi.
have also decided on the final turbo to run im skipping right over the t70 and going right to a gt42. just need to figure out how to get the upper radiator hose connected with that beast of a turbo on there
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Dave, you know as well as I do that driver's make all the difference in the world. Your going to have to take her down the track tomorrow night yourself bro. Are you still using that black jacket as the fire jacket lol....?
nope went out and got a legit firejacket, im not to worried about me driving the car right now i knwo at any given time i can hope in it and make a dead on pass.right now we have limited time before the last chance race (pinks) and she is the registered driver,so i gota get her upto speed on the car soon
i most certianly am
Transmission: 5-speed/T-5
Followed by;
^ Not only is that a contradiction, because the second portion is stating that a tire spinning and slower 60' actually increases speed, EFFECTING MPH....
Let us test this theory of yours. Here we have my friend Paulie running the same EXACT sixty foot in both of his runs (the first and the last), and yet, running an entirely DIFFERENT ET, w/approximately one MPH increase, Click here. Sixty foot was the same, but it didn't underline anything, only the fact that there are way too many variables. Had the trap been slower w/the quicker ET, then I could see the argument, but it wasn't. It increased with the quicker ET. I guess we'll just have to assume that the vehicle's curved rate of speed increase was somehow enhanced by the Gods....
First run;
60-Foot: 1.43
ET: 10:48
Trap: 125.55
Second run;
60-Foot: 1.43
ET: 10:41
Trap: 126.99
First run;
60-Foot: 1.43
ET: 10:48
Trap: 125.55
Second run;
60-Foot: 1.43
ET: 10:41
Trap: 126.99
I was actually just discussing this very thing with a friend of mine and Billy Glidden and his Mustang came up, where when he cuts a good 60' 1.00, 1.01 or so, his trap speed will usually be less by about 4 or 5 MPH, at the end of the quarter, but not always, and rarely would the trap speed ever increase. I witnessed this very thing on quite a few cars last summer at the CSCN, Billy being one very example, on the runs where his E.T. was quicker compared to other runs his MPH would go down. His trap speeds over the entire event were usually slower than other cars in his same class, even though he was running quicker E.T.s than just about everyone else.
You just simply can't base what the trap speed will be on a 60' time. About the only thing you can do is get an average MPH over that 60' distance, but does NOT relate to anything after that.
The 60' measurment is simply used to compare how well the car gains or loses traction at the point where the car transitions from standing still to moving. There's also a loose ralation to overall E.T. but only works if the rate of acceleration is consistant through the remaining 1260', if that rate of accel changes, then 60' times can no longer be related to over all E.T. and definatly not to MPH.
In your ONE example, the car dropped in E.T., which shows that the rate of accel beyond the 60' was different between the two runs, which further proves my point about the 60' E.T. having no relation to trap speeds, and also shows another point that I brought up in this post, about 60' E.T.s having little to no effect on overall 1/4 mile E.T. Thank you. I appreciate it when other people prove my points.
Dave, while you are spending all this time and money on the car - would you PLEASE take a few moments and send the parts I have been waiting for since last Aug?
Rob, I'm the only one who is planning a twin turbo build here and can't help that I feel that stament was directed at me?
Six Shooter, my mind is still yet to be changed. I'm not about theory, I go by FACTUAL proof, not opinionated conjecture. I provided a video to back up my claim, whereas you continue to put forth only an opinion. You stated before that a car that is "spinning" will reach a higher speed, then CATAPULT the car forward once it hooks. Are you serious? WAY TOO MANY VARIABLES to make this an undeniable fact (power to weight, amount of boost, and amount of TORQUE, for starters). In Dave's case, as well as the car he raced, once the car hooks from spinning, the dramatic increase in load will immediately DECREASE in mph, not retain the same mph it achieved spinning and spinning, in a non moveable state....
Originally Posted by Six_Shooter
In your ONE example...
...the car dropped in E.T., which shows that the rate of accel beyond the 60' was different between the two runs, which further proves my point about the 60' E.T. having no relation to trap speeds
well instead of the track this week looks like were hitting the dyno instead,ill know for sure later int he week once i hear back from the place were getting the car dynoed at,Once there sure they can or cant fit us in on friday,if they cant we will hit the track again instead
^ TurboTrix, Click Here.....?
^ I was referring only to they're dyno time of course, not they're engine tech....
they wont let me in the back when they dyno the car,so i said **** it, i found a place to dyno the car for 95$'s an hour and they have the right stuff to make 1/4 mile pulls on the dyno so i can actually do a full pull from a dead stop and see what the curve in each gear looks like so i can play around with the gear ratio a lil bitthough i do belive i have it dead on with the 26 inch tire and rear gear would put me at 7350 rpms at the line when i get the car setup with the spray and big turbo for a 10.90's pass dosent leave much room to grow but without the comp liscence im limited to 135 mph anyway, quick cals show top speed at redline to be approx 143mph so it gives me just enough room to go a lil fastre then 10.90 once the car is completly setup, though it dont take into account tire growth
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Originally Posted by project89
they wont let me in the back when they dyno the car,so i said **** it, i found a place to dyno the car for 95$'s an hour and they have the right stuff to make 1/4 mile pulls on the dyno so i can actually do a full pull from a dead stop and see what the curve in each gear looks like so i can play around with the gear ratio a lil bit....
Originally Posted by Street Lethal
Will be able to run this Wednesday night with you....
wensday isnt looking to good friday would prolly be a better bet
^ I know, the weather has been suckie lately. Only good part though, is my allergies are finally clearing up with all of this damn rain. Gonna invite some of the guys from NYTHIRDGEN down to join us Friday, again, if it doesn't rain....
Car: '85 maro
i just hope she dosent scare the **** out of herself when the front end is a ft off the ground lol i know it will do it **** the car pulled the right front on the slicks @ 6psi with cut down stiff *** 1le springs
Fridayshould be an interesting day im going outside in a lil bit to reinstall the morosso trick front springs and 11 psi waste gate spring
11 psi should be enough with the 6psi spring it just pops the right front 11 psi si this turbos max car wont have anymore to it after the spring swap till i goto the larger turbo,which i might add is huge, wieghs in at a hefty 42 pounds and is being mounted over the battery tray. so i need a few more things befor i can install it, 18 ft of o gauge cable, remote battery disconect and a battery box. and then i have to figure out how to make the ps side headlight assembly removeable and reinstallable with ease.so i can pop it in and out at the track
and then i have to figure out how to make the ps side headlight assembly removeable and reinstallable with ease.so i can pop it in and out at the track....
ahh the h4 suburban headlights they fit i made up brackets for them.but i broke on of the lenses drop the dam thing.they fit nice but it looked to umm 300zx ish.but it might be something i have to look into again.unless we decide to take the car off the road completly then im just going "mustang style" inlet bell to replace the headlights on that side
unless we decide to take the car off the road completly then im just going "mustang style" inlet bell to replace the headlights on that side/
lol u knwo it but it all comes down to money and just how streetable the car is when its all done.
Come on now, streetable? These fella's are running in the 8's and 7's, Click Here, and Click Here. The true definition of streetable is only really defined by the driver....
kinda hard to fit a baby seat in the back of a caged camaro lol,let alone 2 ppl if the passenger seat is removed for a water to air intercooler
lol i wanna knwo how that vette gets threw tech with a swingout,swingouts are only legal to 10.00 9.99 and better u cannot have a swingout
lmfao u knwo if i go shes gota go if shes gota go then the babys gota go sigh
ambainb
Apr 25, 2016 09:21 PM
