super charger maybe
Old Apr 29, 2008 | 05:52 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
super charger maybe
since everyone is talking about turbos has anyone tried to put a supercharger on there sixer?
Old Apr 29, 2008 | 06:11 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: super charger maybe
Faegol used to make them but went out of business a few years back so your SOL with a blower.
Old Apr 30, 2008 | 12:57 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
im planning it, roots old skool type with 4 barrel setup. no idea what figures ill get but ill start small and see what hapens, im not a big fan of turbos. guna take me a while though so dont hold your breath!
p.s. has anyone got any good info on head work when using forced induction?
Old Apr 30, 2008 | 01:26 AM
project89's Avatar
look for a paxton pb600b i belive its paxton neway
http://cgi.ebay.com/ebaymotors/P600-...QQcmdZViewItem
^6 that would be the one to use
Old Apr 30, 2008 | 11:13 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
some people have made the M90 from a T-bird work on the 60v6 since it can be mounted remotely. You can get upwards to 16psi and with some pulleys and porting you can get 20psi and it is efficient enough and creates boost in all the right places a charger should.
Old Apr 30, 2008 | 05:52 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
i could be wrong but isnt this charger kit only for carborated cars, his is a 91 so its probably fuel injected just my
Old Apr 30, 2008 | 06:00 PM
project89's Avatar
those will work with either carb if u have one meant for blow threw setup, or fuel injected, finding a blow threw carb for a v6 may be a lil tricky though,
Old Apr 30, 2008 | 07:27 PM
firstfirebird's Avatar
Centrifical is the way to go for ease of installation, Eaton for cost if you can fabricate.
I have a nice GM Eaton that's ported by about 1mm and has new bearings/seals installed if you'd like, but it's not as easy as the Ford units to retro-fit to your car.
Old Apr 30, 2008 | 07:44 PM
http://s158.photobucket.com/albums/t...dfirebird/M90/
Old May 1, 2008 | 11:26 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Step 1: Remove 2.8 or 3.1
Step 2: Install ford supercharged 3.8L
Well at least thats the route i'd go if i were determined to have a quick "cheap" V6 f body, more realistic V8 swaps aside.
Old May 1, 2008 | 11:43 PM
Why even think about modding the iron heads when 225whp has been done NUMEROUS times on the 60* GM platform? 400+hp has been done with boost and Gen3 top ends.
The Ford motor is even a worse idea.
I'll be dissapointed if mine doesnt make 250whp N/A
Old May 2, 2008 | 06:58 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have one too. But its on my car
Somewhere, there is a guy with a teal 3.1 with a supercharger. I think its a novi2000????
Old May 2, 2008 | 12:23 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
It would be easier to install the T-bird M90 in a camaro and it has been installed in a Fiero so its just a matter of how good you are with a welder. Right now all my money is going into rebuilding the 3.4 in the firebird and rebuilding the T5 in my 92rs but I have a the said M90 and intercooler. I have sized it up on all the cars and the easiest one would be my 78 monza but there isn't many chargers that could handle 10,000rpms so installing it in the firebird is a given unless I score this 87 trans am then I could put it on there. Ported and pulley on the M90 could get you alot of psi and really early since my budy had a supercharged t-bird that thing would scream and it could run with the V8s but I remember he got spanked by a turbo saturn (mini tub well hidden and about 28 psi and one hell of a sleeper)but with a stock set up ran 210hp 315tq and exhaust system that made our stock system look like it was made by flowmaster.
Old May 2, 2008 | 12:28 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
xx
Last edited by crytical point; May 2, 2008 at 12:29 PM. Reason: sorry double posted
Old May 2, 2008 | 08:17 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
If you removed your a/c and fab a bracket for the charger im pretty sure that would work. New ic pipping, injectors and with a 3.1L ECM i dont see why it wont work
M90 would work the problem is making your own custom intake manifold. If you put a custom manifold and nice aluminum heads it would be a beast with a M90. Does a M90 even make a sound lol? Kenne Bell would wake people up. Then again you can also remote mount the M90. Either way life going to suck trying to make a super charger work. Turbo FTW!
Old May 2, 2008 | 09:56 PM
The M90 is not that great. it was designed for a 3800 motor that doesn't breathe. The 3x00 heads would be a better option, that with a turbo makes some nice power. I built a nice turbo kit for a 3400 with 3500 heads, and it keeps blowing transmissions. Winds to 6500rpm no problem, 6psi by 3500. The guy is now talking about selling it before putting another trans in (3 since Dec).
Old May 3, 2008 | 12:09 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
The M90 has a AWSOME sound and I will say it again that the ford M90 is just as good as the GM and alot easier to mount than the GM counterpart since air goes in the back and comes out the top and it is real basic.
Old May 3, 2008 | 10:34 AM
KBcobra's Avatar
Engine: 3.1L V6
If you want to die a very painful but awesome death install this LS1 with a Kenne bell http://www.youtube.com/watch?v=gLBHsFYsIck
Old May 5, 2008 | 01:11 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Just an idea but its possible.
Last edited by crytical point; May 5, 2008 at 01:16 AM. Reason: Automerged Doublepost
Old May 5, 2008 | 09:30 AM
Dale's Avatar
Engine: 350 S-TPI
Is that the ford m90? what it come off of?
Old May 5, 2008 | 10:16 AM
You can tell the Ford M90's by the fact that the intake and discharge is on the top/bottom. They cane in the Thunerbird S/C 3.8L, mounted remotely already.
The one I posted a lik to earlier in the thread is a GM M90, where the TB is on the opposite end of the snout - making it a bit more difficult to remote mount.
Old May 5, 2008 | 10:21 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
actually the intake side is on the back of the ford m90's and I was putting that in different places and it is possible to mount it on top with alot of fabrication. I might just put it down where the air pump use to be because loosing ac is not an option.
Old May 5, 2008 | 07:30 PM
Dale's Avatar
Engine: 350 S-TPI
I know what a GM M90 looks like, I drive one almost every day.
But that didnt look like the mustang or Lightening S/C either as they still have rear entrance like the GM one... however, the rear of them unbolts and you can fab up your own inlet very easy.
Old May 5, 2008 | 08:14 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
ok i have a questions since mine is MPFI what can i do
Old May 5, 2008 | 08:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
remote mount it
Old May 5, 2008 | 08:20 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
thanks i jus realized that when i saw a pic of it but i got another one for u so what has to be done to the internals of the engine and it will jus bolt up to the manifold to do this
Old May 5, 2008 | 08:53 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Depending on the mileage...a rebuild is good. And you will need bigger injectors and give your ECM a tune or a FMU.
Also, it wont just bolt up. It has to be mounted over the valve cover and routed to the throttle body. It will have to be a custom job.
:EDIT: I know its on a V8...but the concept is the same. It will be done something like this...
Old May 6, 2008 | 12:30 AM
UDAMON's Avatar
Car: Mazda Protege5
what about a setup like this?
Old May 6, 2008 | 06:57 AM
Dale's Avatar
Engine: 350 S-TPI
thats the corvette one isnt it?
As for the TPI motor.... I'm surprised they didnt put the TB on the inlet side of the SC. But then I guess that setup is more like a "turbo" style plumbing.
Ideas
Old May 6, 2008 | 08:31 AM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
If we are thinking of the same car, it was the Teal 3.1 Camaro from TRC Performance. I exchanged quite a few emails back n forth with the owner as I had LOTS of questions about the fabrication. Used to have the car posted on the site with a bunch of pics n vids but its been down/moved for quite a while now....
Aslo had a very nice 5.0 Mustang (Sorry, I'm a car guy... SUE ME!)
Old May 6, 2008 | 09:44 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I will see if a top mount is possible even if it is like a thunberbird setup you will keep AC and it will look pretty good.I have heard of guys running 9-12psi on stock 3.4 pistons and if you go forged you can get more. I was saving that m90 for a old school 3.8 and 4spd combo in a ultra light auto X car but I think a 3.4 and 700r-4 in a firebird would be a little more fun considering I have a cosworth 4cyl for auto X. People will tell you that turbo's are more efficient and if matched right will have like no lag but show me a turbo that keeps its efficientcy while giving boost at 1500rpms and can give you 20 psi at 5000rpms and give you the loud whine. As far as most people consider turbo or supercharger I like having my power where I will use it the most.
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
Formula_88AE
Sep 3, 2015 01:47 PM
