stupid crank pulley.....
Old Apr 30, 2008 | 10:20 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
This is probably something really easy, but I'm not seeing it after a few too many beers.
When trying to take off the crank pulley, how do you keep it from rotating the crank? 5 bolts to undo, but all I'm doing is spinning the engine.
Old Apr 30, 2008 | 10:32 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: stupid crank pulley.....
use an impact, it's my best friend
Old Apr 30, 2008 | 10:36 PM
Car: 1991 Firebird
I wish. Low tech garage here. Any other options?
Old Apr 30, 2008 | 10:50 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Use a prybar or screwdriver to hold the crank pulley. Use either in the teeth of the starter gear, or through the balancer, against the bottom of the oil pan rail on the block.
Old May 1, 2008 | 10:56 AM
Car: 1991 Firebird
That worked. Thanks.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
djmarch
Oct 2, 2015 10:41 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
