3.1 block, 2.8 parts
Old May 1, 2008 | 02:23 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Alright so my 2.8 went on me about a month ago, i was told the 3.1 is basically the same engine and whatnot. So my question is, with a 3.1 block and like the intake manifold, fuel rail, and such on that 3.1 bloc, am I gonna have any problems? I already got the engine put in but cant start it till I get a new engine. Will I have any problems with the computer or anything? Thanks.
Old May 1, 2008 | 02:25 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: 3.1 block, 2.8 parts
Nope. It's all the same. The 3.1 lacks a cold start injector, so your 2.8 wiring harness will have a plug that goes to nothing. I'm pretty sure that's about it though.
Old May 1, 2008 | 03:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm kinda lost here. You say you have the new motor in. But cant start it tell you have a new motor.......... which you say is already in?
The throttle body mounts to the upper 1/3 intake differently between the 2.8 and the 3.1. The 3.1 also has an extra vac line port, which can be easly capped.
Best bet is to use your 2.8 upper 1/3. Middle 1/3 section wont matter. Then match your lower 1/3 to whatever fuel rail you use.
Old May 1, 2008 | 03:17 PM
Ah man hadn't realized that. Got the motor in , can't start till I get fresh oil in it and a new battery (someone stole my other one). So yeah, I did use the 3.1's bottom half of the intake, then used my 2.8 top half of the intake. Used the 2.8 fuel rail so the CSI was plugged off, the 2.8 oil pressure switch won't work with the 3.1's.
Old May 3, 2008 | 12:13 AM
Well got everything all hooked up, ended up using the 3.1 rail/injectors because of the 2.8's fuel rail CSI was leaking fuel. But I got one problem, engine turns over fine, but no start, got the firing order correct. I do have those 3 relays on the driver side firewall unplugged, would this make a difference? Do those 3.1 injectors need a certain PSI?
Old May 3, 2008 | 01:00 AM
project89's Avatar
yes u need those relays pluged in one is for the fan, i knwo for sure the other for the fuelpump?,and i dont know what the 3rdwould be for mine only has 2
Old May 3, 2008 | 09:09 AM
yeah your right, it only has 2. well got those plugged up and i dont know what happened between last night and now, but when i go to start the car, it dries to crank then it seems like the engine cathes on something, then it stops, and its like a cycle
Old May 4, 2008 | 06:59 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
What do you mean its a cycle? like a "click click click" sound? or do you mean it does it once every time you hit the key? make sure you have enough voltage left in the battery, from what youre describing, thats what it sounds like.
Old May 4, 2008 | 03:27 PM
yeah i was having problems with the battery. the guy i got the car from actually got it running, came over and had it started in seconds. it was the firing order, instead of firing on cylinder #1, it was firing on cylinder #2. another 3rd gen brought back to life.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
guy76767
Aug 6, 2015 05:58 PM
