Any cheap modifications while she's already in pieces?
Old May 11, 2008 | 01:04 AM
threepointone's Avatar
Car: 1991 Camaro
Engine: LH0 3.1L V6
Transmission: uhh... an automatic one.
Axle/Gears: um... these ones... *points*
Gentlemen,
I was curious as to what else I could do (free-$50) while I have everything down to my valve covers off. I'm currently just planning on putting in the E67E-B1B injectors and now an un-planned valve cover factory-match paint job, along with a new stat. I've already done the basics... distributor O ring, new cap and rotor, spark plugs, and fresh wires. Is the "penny mod" on the FPR worth doing for power? I'm not sure how it's done though...
Thanks.
Old May 11, 2008 | 12:13 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Any cheap modifications while she's already in pieces?
port the intake, port exhaust manifolds, port/gasket match, cold air intake. the iron head 2.8 is not a performance engine and you shouldn't expect big power. If you want huge power from a V6 then swap in a 3.8 either a 4th gen 3800 or a early 3.8 from 78-87 and go turbo. I am doing all the cheap power mods to a 88 firebird for my girlfriend to drive because my l03 5spd camaro has to much power for her (kinda sad) but you can get about 200 whp out of the 2.8 as the Fiero guys have found out. But if you want some decent power out of your 2.8 then swap fiero/3.4 heads because the Fiero got the 2.8 H.O heads which are 3.4 heads so there ya go.
Old May 11, 2008 | 12:17 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
That was already dispelled in the other thread you brought it up. The heads are the same. https://www.thirdgen.org/forums/v6/4...rt-polish.html
Old May 11, 2008 | 12:31 PM
oil pan 4's Avatar
Car: 89 Firebird
Replace the valve cover gasket, it won't help power but it will keep oil leaks away.
Cleaning all the gunk out of the intake helps. Maybe change out your thermo stat. If your going to pull the intake manifold off you can enlarge the coolant passage to match the head. I removed a little more than 1/16'' all the way around the opening.
Old May 11, 2008 | 03:24 PM
Car: 1991 Camaro
Engine: LH0 3.1L V6
No problem- I've had a set sitting and waiting for me to do this for some time now.
What is the best way of doing this? It seems like a rubber coating that was meant to be there...?
Crytical Point: Not really looking to suck this thing dry for 200hp... I'd just put a 75hp shot or a swap for some major gains, but not at this moment. I'm just trying to make a decent and reliable daily driver out of a $900, 63k original mileage vehicle.
Thanks for the replies!
Old May 11, 2008 | 04:05 PM
oil pan 4's Avatar
Car: 89 Firebird
Any thing, depending on how hard it is. Any thing form a screw driver and wire brush to pressure washer, parts washer and break/carb cleaner.
There is no rubber coating in side the intake plenum or manifold. That is the gunk, if its rubber like then try a pressure washer then spary cans of cleaner. That should work fine.
Old May 11, 2008 | 04:17 PM
Car: 1991 Camaro
Engine: LH0 3.1L V6
Thank's alot- will do!
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Justins86bird
Sep 27, 2015 09:43 AM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
