Injectors
Old May 30, 2008 | 01:43 PM
kukerdan's Avatar
Injectors
Hey, there's really nothing on here about injectors,
besides that Ditch your stock injectors post, which ive read thru,
Question is.. my car is about to hit 120 K, runs gr8, but im
going to start doing things like A ported and polished / port/gasket matched intake, and headers, and want to know how many horse i can hope to get
out of the stock 15's ?
are there new modern 15 #'s that can go in, with no computer mods,
and give me power and economy benefits?
Old May 30, 2008 | 01:54 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Injectors
Yes, the Ford F1ZE injectors, detailed in the 'Ditch your stock injectors' thread.
Old May 30, 2008 | 05:17 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Injectors
I'm running 3.1 injectors in my 2.8 and they are fine. They gave me a little more power in the top end, or atleast it pulled to higher RPMs. I haven't had any problems with them and my fuel economy went up actually but that may be in part to my old worn out 2.8 injectors.
Old May 30, 2008 | 10:14 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Injectors
15 lb/hr injectors on a v6 are good to ~150hp. 21 lb/hr would be good to ~220. You can raise the fuel pressure to get a little more flow out of the injectors you have. At 55psi stock injectors would flow 18.3 lb/hr.
Old May 30, 2008 | 11:07 PM
Picolini's Avatar
Car: No F-Body right now
Re: Injectors
Could I get a link to this "ditch your stock injectors" thread? I can't seem to find it through a search.
edit: Forget it, I found it!
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
