91 rs 3.1 timing prob
Old Jun 5, 2008 | 03:32 AM
Jman03's Avatar
ok so i changed all the things you should when you buy a camaro for dirt cheap. to try and find the problem.
changed plugs/wires
dist cap & rotor
fuel filter
air filter
all the vacume lines
map sensor
oxygen sensor
has 42psi from the fuel pump
and probley something else i cant rember
so heres the problem i have it timed 10 degrees like it should be was at 16 when i got it. when you accelerate their is no advance on the timing light
it just sits at 10 degrees then at about 2000rpm the air pump backfires
any help is appreciated thank you
Old Jun 5, 2008 | 07:38 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 91 rs 3.1 timing prob
There is a wire that may be disconnected. It is behind the passenger strut tower comming out of the wiring harness and going back into it. Its a brown wire with a white stripe in my car. If is is disconnected then the timing won't advance.
Old Jun 5, 2008 | 05:58 PM
Jman03's Avatar
isent that the wire you have to take off to time it the electric spark control or something like that then you plug it back in after timming the car?
yes it's pluged in
lemme try and describe it again i dident do a very good job last time.
watching it with a timing light i bring it up to 3000rpm
but it isent advancing it just sits at 10 deg.
so is their a worn out part in my dst. or what?
Old Jun 5, 2008 | 06:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I understand your problem, I didn't hook that wire up once I retimed the car and it did the same thing. That is the only thing that I can think of. You may want to check for strong or weak spark.
Old Jun 5, 2008 | 11:35 PM
Jman03's Avatar
the spark is whit hot thanks for helping
84z96L31vortec
Aug 20, 2017 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
