AC Blower / how to make it colder
Old Jun 9, 2008 | 12:23 PM
kukerdan's Avatar
Hey guys,
I just had the condenser replaced in the car, and R-12 put in,
Blows nice and cold.
The vents seem a little lacking in air flow,
I was wondering if they make a high speed blower motor
or If theres a Cabin Air filter, or what.
I want more air comming out of my vents!
Also, my vents are limp, they dont stay where I put them,
Whats my best bet on fixing those?
Old Jun 12, 2008 | 12:32 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: AC Blower / how to make it colder
Not really much you can do about the amount of air coming out. It's a limitation of the blower motor itself. I havn't seen anyone mod something up to make it faster or put in a different one.
As for the vents that move around...head down to your local home and garden center and pick up some self sticky 1/4" wide, 1/4" thick insulation, the kind you put around window A/C units. Remove the vents carefully with a pocket screwdriver and put a small strip of the onsulation on both sides of the vent.
The foam acts as a friction material and keeps them in place while you drive.
Old Jun 14, 2008 | 01:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
As for your airflow problem, your car IS 20 years old now. All of the cruddy foam insulation between the plastic ducts is probably degrading and letting air out from the joints. Also, your wiring is also 20 years old. You might be better off running some new wiring to the motor and the high-speed relay, but only after you have exhausted all other options.
Old Jun 14, 2008 | 01:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
After I replaced the blower motor, I was surprised at how much harder the air blew--I shouldn't have been amazed, I guess, hey the motor was 20+ years old.
JamesC
Old Jun 14, 2008 | 06:31 PM
project89's Avatar
i wa sreading here on the boards somewere about guys using diff refrigerant, r12 replacement stuff that supposedly blew alot colder air temps. try searching for it
Old Jun 14, 2008 | 06:57 PM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
r414b "hot shot" it's a little colder, unless there's another one you're talking about...
Old Jun 14, 2008 | 07:03 PM
project89's Avatar
i cant think of the name right now but ill search the boards in a bit for it,they were saying it blew alot colder then the r12
Old Jun 14, 2008 | 07:58 PM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
To my knowledge, they don't make R-12 anymore b/c it was supposedly "bad for the environment" so that's why they came out with the R-134A. I know of other types of refrigerant, but to my knowledge, they discontinued the R-12 and they make adapters for the new stuff R-134A to connect to the old fittings under the hood. But I could be wrong.....
Old Jun 14, 2008 | 09:11 PM
JamesC's Avatar
R12 is still available. I'm taking the car in for a charge Monday. I doubt you'll find anything that will blow colder in our systems. I had no luck with 134.
JamesC
Old Jun 14, 2008 | 09:59 PM
project89's Avatar
here u go it took a while but heres the thread the stuff is called autofrost theres more threads on the stuff, some ppl had issues with icing though
https://www.thirdgen.org/forums/cooling/428019-r406a-autofrost-review.html
link fixed
Old Jun 15, 2008 | 12:36 PM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
I am recharging my air conditioner as well. I have been reading up on this and I have one question: if I go with R-134a instead of the R-12, then do I need to do some oil change or can i just vacuum out the system and just refill with the R-134a?? If I need to change the oil, how do I do this?
Old Jun 15, 2008 | 12:57 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
If you go to R-134a the only way to make it blow cold is to completely vacuum and drain the system. Replace the accumulator/Dryer. and recharge with the new oil, refrigerant and parts.
If you can find R-12 at a resonable price.. use it.
DONT USE ANYTHING ELSE... freeze12 or any of the other "stuff" has additives that are harmful to technicians tools... if you put it in your car then take it to a shop they will not work on your car. Also never use anything that has sealer in it...
I was a tech.. i know
Old Jun 15, 2008 | 01:43 PM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
I get what the refrigerant is, but what oil???????? Do you mean the accumulator/dryer when you say parts??
Old Jun 16, 2008 | 10:21 AM
kukerdan's Avatar
ester
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
mhatfield 14
Aug 15, 2015 10:47 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
