Cams/lifters
Old Jun 4, 2008 | 12:35 AM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Cams/lifters
I am slightly "building out" a 1986 2.8L camaro drive line (basically making it a show car). But I want a little more nut behind it (if you know what I mean lol). I found a cam/lifter kit on Summitracing.com. Here it is: http://store.summitracing.com/partde...&view=1&N=700+ In addition to this, I want to make it a 10.5:1 compression. What other modifications would I have to do to make this work properly. Further more, can someone please explain to me what all of the detail means about the cam/lifter kit?? What is the "Intake Duration at 050 inch Lift -- 204"? Does this mean that the intake valves stays open 0.204 seconds and they open 0.050 of an inch? Someone with more knowledge on this PLEASE break it down for me.
Old Jun 4, 2008 | 12:44 AM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: Cams/lifters
Will I need new rocker arms? What does the ratio mean when talking about the rocker arm ratio??
Old Jun 4, 2008 | 03:27 AM
awesome's Avatar
Car: 88 camaro
Engine: 2.8
Axle/Gears: unknown
Re: Cams/lifters
just go to google and type in "how does a cam work" Im sure something will come up that will help you out, once you understand how it works you will understand what all those specs mean.
Old Jun 4, 2008 | 08:02 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Cams/lifters
That Edelbrock cam doesn't work with FI I believe. Look into the Comp 260H. If you want 10.5:1 compression you will need some custom pistons. If you go the 3.4 route you can use the 3.4 DOHC pistons for about 10:1 compression.
Old Jun 4, 2008 | 12:27 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: Cams/lifters
I decided to run the MTC-5 cam..just finished the heads yesterday,ported,springs,retainers,and locks ..my car will be a daily driver with some fuel mileage on the mind.I hope to have it installed by the end of this year.theres lots of options to go..just depends on your wallet and preference?.
Old Jun 4, 2008 | 10:28 PM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
Re: Cams/lifters
if you get the 1.6 ratio rocker arms it will increase the lift by 30 i think, the 1.5 are stock
Old Jun 4, 2008 | 10:43 PM
project89's Avatar
Re: Cams/lifters
260 > mtc 5 yeah stock rockers are 1.5 the meaning is this, say the cam has .200 lobe lift u multiply it by the rocker ratio so a 1.5 rocker gives u .300 valve lift wereas a 1.6 rocker would give u .320 valve lift
Old Jun 5, 2008 | 02:37 AM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: Cams/lifters
Ok. So does "Intake Duration at 050 inch Lift: 204" mean that with stock rockers, the cam's lobe lift on the intake puts out a valve lift of 0.050" for a duration of 204 degrees?? Or does it mean that the lobe has a lift of 0.050"??
Old Jun 5, 2008 | 02:55 AM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: Cams/lifters
BTW, here's more of my parts list. Tel me what you think.
V-6 Oil Pump
V-6 Main Bearings
V-6 Connecting Rod Bearings
V-6 Rocker Arms
V-6 Timing Gear Set
V-6 Connecting Rod Bolts
V-6 Push Rods
V-6 Lifter Link Bars
Old Jun 15, 2008 | 07:06 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Cams/lifters
whats with the lifter link bars? those are for a roller cam dude, and the MTC-5 is not a roller cam, i know cause its sitting in my engine now.
Old Jun 16, 2008 | 11:43 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Cams/lifters
I think you need to understand how an engine works a little better before you go modifying yours. Not trying to be rude, just my .02.
Stekman
Feb 2, 2004 10:35 AM
