v6 rebuild or upgrades
Old Jun 4, 2008 | 09:59 PM
CamaroKingpin's Avatar
Car: '92 camaro rs
Engine: 3.1 v6
Transmission: stock tranny
Axle/Gears: stock gears
got a 92 3.1 with well over 100k. i was thinkin about a rebuild cause i like the six.would i feel a noticable difference or would i be better off just replacing main parts like cam, roller, timing etc..? not sure yet what im gone do. any advice or tips?
Old Jun 5, 2008 | 09:04 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: v6 rebuild or upgrades
I'd do a full rebuild, personally, if it's over 150k.
Old Jun 5, 2008 | 04:45 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
If you are thinking about doing a rebuild then go ahead and do it and add the cam with it. Just with a rebuild you should notice an improvement in power just from getting power back from the high miles and even more from the cam.
Old Jun 9, 2008 | 08:51 PM
Car: '92 camaro rs
Engine: 3.1 v6
im comparing the pricing on rebuilding and a 350 swap, and its looking a little more attractive for a swap right now. different shops are giving me cheaper prices for swapping motor and trans. havent fully decided but im leaning to swap.
Old Jun 10, 2008 | 12:07 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
If you're going to have a shop do it for you a 350 swap may be the better way to go, but you'll save a ton doing it yourself.
Old Jun 10, 2008 | 08:25 AM
project89's Avatar
if u have a shop do a v8 swap make sure they install a new front brake line instead of bending the v6 line to clear.
try to do an l98 swap if thats the way ur gonan go
Old Jun 10, 2008 | 08:06 PM
Car: '92 camaro rs
Engine: 3.1 v6
im get the motor and trans out of 91 rs. im taking the harness,ecu, and brake lines. anything else i should take off the donor?what about driveshaft?
Old Jun 10, 2008 | 08:28 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
If its an aluminum DS then I would grab it, otherwise no. Also something else to replace would be the front springs.
Old Jun 10, 2008 | 08:40 PM
Car: '92 camaro rs
Engine: 3.1 v6
i think going im getting the 305 and 700r4. i think it would be the easiest bolt in because i got an rs and that was a factory option. plus im paying a damn good price. springs makes sense, would i need different struts as well? i am going have a shop put it in, but getting everything i need so there is no extra 'oh you needed this too' charges. would my v6 shaft hold/bolt up to the trans?
Old Jun 10, 2008 | 09:42 PM
project89's Avatar
im pretty sure its the same drive shaft.and yes u deff need v8 springs,if ur gonan do the swap skip the 305 u will be much happier in the long run btw 305 and 350 are externally the same noone would know the diff anyway
Old Jun 10, 2008 | 09:57 PM
forkvoid's Avatar
If you've decided to go V8, go to the Engine Swap forum. There is a motherload of information on the v6-v8 swap, detailing exactly what works and what doesn't, what you need from the donor, what you need new, etc.
Old Jun 10, 2008 | 11:55 PM
bl85c's Avatar
Car: '85 maro
You also need a different radiator, fuel pump, trans and motor mounts. The v6 driveshaft is a little lighter than even the aluminum driveshafts, or so I've been told.
Old Jun 11, 2008 | 12:13 AM
project89's Avatar
last time i cross refrenced the part numbers on the fuel pumps the v6/v8 tpi pump was the same the tbi pumps are diff though
Old Jun 16, 2008 | 04:12 PM
Car: '92 camaro rs
Engine: 3.1 v6
thats why i was thinking of getting mechanicaly sound camaro,but with a beat up body for a donor. and what i dont use part out. get some of that money back.
Veaceonee
Sep 29, 2016 08:15 PM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
tonys91rs
Oct 10, 2015 03:31 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
