another one with bad mpg! ideas......? thanks!
Old Jun 16, 2008 | 10:04 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ok, 10mpg - driving like a granny!!
runs fine - starts,stops dosnt moan, lowish power below 2k and above 4.5k
just pulled plugs, white ? dosnt add up to me. last i checked no codes but need to check again.....
Old Jun 16, 2008 | 12:29 PM
92RS3.1's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Axle/Gears: open 3.23
Re: another one with bad mpg! ideas......? thanks!
I suggest looking into the egr valve. Doesn't take too much time. lotsa info in
92 3.1 EGR Problems @ 9 mpg Code 32 on my and a few others EGR problems.
At the worst point, I was driving with a feather-light foot and still got a constant 9mpg or worse. It was a line from the egr to the intake.
Its worth a look. Do you have any codes?
Old Jun 16, 2008 | 12:41 PM
project89's Avatar
if the plugs are white that means the car is running dead lean,do u mean the insulator is white,or is the entire end of the plug white?
Old Jun 16, 2008 | 12:49 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Lets start with the plugs, what brand?
Old Jun 16, 2008 | 03:08 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
right guys thanks for looking, ive fitted new plugs (champion) gapped at .045 - the ones i removed were at .035 (ngk's) the insulator and tips were white though curiously round the outer edge was rather black
ive blocked off the egr
ive played with that bliming charcoal canister
i had a trundle up the road and theres a hell of a lot more power below 2k and higher up now, im guna read codes tmrw, and use it and monitor mpg
i cant smell gas anywheres so im hope-ing theres no leaks
ill update later
Old Jun 16, 2008 | 03:28 PM
project89's Avatar
can u take a picture of the plugs?
Old Jun 16, 2008 | 06:48 PM
Kevman's Avatar
Engine: 2004 LQ4
NGK plugs run really hot, try using AC Delco, they're like $1 a piece and they run perfect for our cars. They'll run half as hot.
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
my86bird
Oct 23, 2015 12:20 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
gta892000
Sep 16, 2015 12:40 AM
