Why has my rev counter needle...
Old Jun 12, 2008 | 04:06 PM
autoholic's Avatar
Car: 1988 Camaro RS, 1972 Dodge Dart
gone and sat on 7000??
My 88 Camaro is STILL off the road and in a local garage. Trouble is they don't know the first thing about it.
After replacing all the parts mentioned in my previous threads it was decided the over fuelling problem was down to the MAS. So I got one from a company in MI. Shipped to the UK, fitted and the car ran!!
So we set the timing, shut it off, started it, repeated this a few times. Happily parked it awaiting it's road worthyness test the following day.
Sadly it wouldn't start. I cranked it for a bit and got a couple of rev out of it but it died straight away. The needle on the rev counter then swept round to 7000 and that's where it's stayed.
I've bought and replaced the battery with today it only cranked with no sign of a fire. Any ideas guys??
I really need help o with this car before it set fire to it!!!!!
Cheers
Steve
Old Jun 12, 2008 | 09:31 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Why has my rev counter needle...
Ok, by "rev counter needle" I assume you mean the tachometer. As for it sitting in the red, it is fairly common or the tachometers in these cars to be WAY off. Something with the resistors going bad. All I'm saying is that it may not be related to why your engine is not running. First, make sure your engine is getting fuel, if thats within the parameters, move on to the ignition system. Buy a spark tester (or just make one out of a good spark plug), check it at the coil wire, then check each plug wire. If that all checks out, ensure that you have working plugs with the proper gap. Is your exhaust equiped with a CAT? They can become clogged an cause all kinds of problems.
(fuel+spark)X(air in+Exh. out)=Vrooom vrooom
Good luck,
Max
Old Jun 15, 2008 | 07:34 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
don't forget to check the dumb problems that are easy to overlook. bad connections, corrosion, or wires that aren't connected to anything. stuff that could easily be your problem
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TrevinE
Sep 14, 2015 03:20 PM
roysatikas
Sep 7, 2015 08:08 PM
