removing canister - quick question
Old Jun 21, 2008 | 09:27 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
i take it most cars had non vented caps? what does a vented cap look like?
i thought about using a pcv valve on the vent line going to the canister-when removed, so it only lets pressure out when needed ?
any points or ideas on this? thanks guys
Old Jun 21, 2008 | 10:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: removing canister - quick question
Tank has a vent above the rear axle. Check the passenger side (UK) for a hose with a plastic 'mushroom' on the end of it. That is a 2-way vent to control the tank pressure/vacuum.
RBob.
Old Jun 21, 2008 | 11:22 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
hi thanks, yeah i knew that was there but couldnt find any info on it.
i herd it was oneway only ? ive never had pressure in the tank untill i blocked the canister pipe - now i get that woosh when i take the cap out. car drives fine so i am not too bothered aslong as the tanks not guna explode !!! lol
Old Jun 21, 2008 | 11:57 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Just wait till you get low on gas. From the pressure built up the fuel pump will start howling. A vented cap looks just like a regular cap. The only thing you do is after it is tight turn it back like a half turn to the tank can vent.
Old Jun 21, 2008 | 01:22 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
one thing i have noticed is that one problem - stutering between 2-3k and in bends has stopped ;-) looks like ive fixed my previous post of 9mpg with this as well fingers crossed
thanks for the help and advice
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
jahblah
Aug 12, 2015 05:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
