fuel injectors
Old Jun 19, 2008 | 09:01 PM
91Camaro_RS's Avatar
fuel injectors
so i figured out my problem, it was the fuel injectors that was making my car run abnormally, so i dont really have much money to have them installed so i was thinkin how hard would it be to put them in myself?
Old Jun 19, 2008 | 11:02 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: fuel injectors
Its not that hard at all. It will be a little akward pulling out the fuel rail for your first time.
Old Jun 20, 2008 | 07:01 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: fuel injectors
Its not that hard at all. You will need a torx set of sockets and various size strait screwdrivers.
The main part that sucks is paying 20 bux to use 2 small gaskets
Old Jun 20, 2008 | 01:15 PM
Re: fuel injectors
so when i get the new injectors i have to go get the 2 gaskets?
Old Jun 20, 2008 | 04:28 PM
Dale's Avatar
Engine: 350 S-TPI
Re: fuel injectors
You have to buy a whole kit which has about 12-14 gaskets.... and only use 2.
Plus if your new injectors dont have new orings, you have to put new orings on them as well.
Old Jun 20, 2008 | 05:10 PM
Re: fuel injectors
ok so here is the injector that i found does this have the o-rings on it already, to me it looks like it does
http://www.partsamerica.com/ProductD...pe=677&PTSet=A
and are these the seals/gaskets you were talkin about:
http://www.partsamerica.com/ProductD...pe=752&PTSet=A
i am reading my repair manual and it says that i also need a new o-ring for the cold start tube and a new gasket for the intake plenum, i tried searching for a o-ring for the cold start tube but didnt find anything, is there another name for it?
Old Jun 21, 2008 | 07:53 AM
Dale's Avatar
Engine: 350 S-TPI
Re: fuel injectors
First I see you have this listed on a 91 Isuzu? Is that right? And if so, is it MPFI? (or is that a leftover car from something I did?)
Injector looks right...for a camaro. Appears it has orings, but just look at it when you pick it up.
Gaskets, no that is not right... If your a camaro, you will need http://www.partsamerica.com/ProductD...pe=102&PTSet=A
A 91 model does not have a cold start injector. That is for 85-89/90'ish.
Old Jun 21, 2008 | 07:52 PM
Re: fuel injectors
so that $30 worth of gaskets is all i need, the plenum gasket and everything?
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
