So I wanna pull the motor and change the manifolds.. A few q's.
Old Jun 25, 2008 | 05:49 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, my manifolds are leaking badly and throwing off my O2, the weekend after this one I would like to pull the motor, and re-do the manifolds, rear main, clutch, intake gaskets, oil pan gasket, and freeze plugs. I just want to know, is it very difficult to pull the motor out of one of these cars? Will it take 2 weeks, or a few hours? Thanks, KP.
P.S I have done a bunch of engine pulls in my past, a 400 lb Ford BB/Transmission. So it wouldn't be the first..
Old Jun 25, 2008 | 07:02 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: So I wanna pull the motor and change the manifolds.. A few q's.
it doesn't take long... the hard part is the wiring you have to take off... and the exhaust bolts. the exhaust bolts like to break! but basically to pull a motor is like this:
2 engine mounting bolts
6 trans bolts
4 exhaust bolts
you're done... and TONS of wiring/cables
Old Jun 25, 2008 | 07:28 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
almost easyer to pull the tranny also with the engine since u are changing the clutch.
Old Jun 26, 2008 | 05:47 AM
Kevman's Avatar
Engine: 2004 LQ4
that's true too.. plus pulling the tranny allows me to clean out the oil out of the bellhousing..
Old Jun 26, 2008 | 09:58 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
i would pull the tranny too. that way you get the chance to change the fluid in it and putting it all back in should be a snap.
BRoss99
Aug 10, 2025 05:08 PM
Steve78LT
Feb 24, 2016 12:15 AM
madsv1000
Aug 20, 2015 06:45 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
