to those that understand the ecu's and stuff
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ok so im going for my carb setup shortly - parts on way. the only thing im wondering is if i go from the mpfi to carb can i still get the ecu to sort my timing out ? untill i get a vac advance diz, or will i ever need the vac advance diz ?
please no coments on why im swapping ;-)
thanks anthony
thanks anthony
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: to those that understand the ecu's and stuff
I dont know of any way to make it work.
IIRC timing is based off RPM and kpa. So if you were to attempt to make it work, you would still need the map or maf, along with the ICM. Then custom program the ecm to ignore all the other crap. IMO, it would be cheaper and easier just to go get your vac dizzy.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
there are also standalone timing controllers.
The megasquirt guys make one, if you want the ultimate in timing control.
he has a maf system.in order for the stock ecm to control ignition timing properly u would have to run the maf and air temp sensor,im not positive but u may also need the tps
but i know for a fact without the air temp and maf the timing will be all screwed up
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by zs&tas
ok so im going for my carb setup shortly - parts on way. the only thing im wondering is if i go from the mpfi to carb can i still get the ecu to sort my timing out? untill i get a vac advance diz, or will i ever need the vac advance diz?
zs&tas, disconnecting either the MAF sensor, and/or O2 sensor will force Open Loop, and in this state, the ECM doesn't control spark advance, the distributor does directly. It is preset to do this in something known as Bypass Mode. I did this very thing on my old LB9, and just did this to my new LG4, and it worked fine (once you adjust the air/fuel ratio on the carb). Some will argue that the stock parameters aren't too great in Bypass Mode, and I agree, but it will work, you just need the carb, set the ECM to Open Loop, and get a lockup kit for the tranny.
^ Umm, Dave, the MEGASQUIRT is a completely different animal. The stock ECM does not control timing/advance with an open circuit prevalent, the HEI module in the distributor does, which is the reasoning for the Bypass Lead wire. Under 2-volts, and/or Open Loop, the ECM does not control timing whatsoever....
might as well not install the ECM then.
The HEI module is completely capable of sparking on its own.
Originally Posted by Toehead
might as well not install the ECM then. The HEI module is completely capable of sparking on its own.
Originally Posted by project89
the megasquirt wa sdoing fuel control only remeber, i had it piggy backed
no when i ran piggy backed i still used the stock ecm,the mega squirt had its own o2 tps and ait cts sensors,nothinhg was disconected fromt he stock ecm
Yeah, but not only do we not know that it was the spark advance causing the spark knock, were you running Open Loop constant? The whole point is that it needs to remain in Open Loop, because the ECM SETS your timing fixed to a Zero Degrees Base, with the distributor itself advancing for spark according to RPM being realized. The ECM does not control spark advance in Open Loop, it only sets base, which is why it isn't to be removed....
true but my point is if he keeps all the sensors,including the maf the stock dizzy will work fine,though im not sure if he needs the tps or not
now im curious,but i cant test it out with the megasquirt hooked up lol
What do you mean the ECM sets base timing?
Base timing is set by the user, by phisically moving the distributor?
^ In Open Loop the ECM ignores most of the sensors and sets the timing fixed to base, which normally occurs during cranking/cold start, and/or Limp mode (bypass mode)....
I still don't understand what you are saying.
My base timing is set BY ME at 6 degrees BTDC. The ecm modifies the timing signal to change the timing, but remove the 5 volt signal and it is instantly back at 6 degrees (until a certain RPM, when the module has a built in advance curve. )
What do you mean the ECM sets base timing? Base timing is set by the user, by phisically moving the distributor?
The ecm modifies the timing signal to change the timing, but remove the 5 volt signal and it is instantly back at 6 degrees....
The ECM, in Closed Loop mode, alter's (as you just pointed out) Open Loop mode's base timing. With a 5-volt signal prevalent (Closed Loop), in my LG4's case, it has a 6 degree base timing. With a 5-volt signal NOT prevalent (Open Loop) it reverts back to a 0 degree base timing. I'm referring to "reverts back" because Open Loop occurs FIRST, not Closed Loop....
You still don't understand yet?
As for Spark Advance, as I mentioned a few posts up, this occurs when a reference pulse, determining engine RPM, is fed back and forth (in either Closed or Open Loop mode). Spark advance occurs either with the ECM's help, or without (Closed or Open circuit)....
Ok, I understand what you are saying.
Building a megasquirt for a car with no harness really gets you familiar with EFI, so I know how and why the HEI system works, I was just trying to figure out what you were saying
Sorry for the confusion.
My base timing is set BY ME....?
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
i'm going to have to read that all over again several times. lol
It's easier to understand when you look at the schematic view of the EST circuitry. I've tried my best to explain it, but I'm going to try to get a scan of the schematic's up very soon....
The HEI ignition module has seven terminals (eight, if you include the ground);
* Battery Terminal
* Ignition Coil Trigger Signal Terminal
* Pickup Coil Signal Converter
* Compensated Ignition Spark/Timing Signal (to ECM)
* Crankshaft Position RPM (to ECM)
* Bypass 5-Volt Disable (to ECM)
* Ground (to ECM)
The Bypass is literally a coil inside of the ignition module, and when it is in Closed Loop (at the proper voltage), it's leads are directed from the Ignition Coil Trigger Signal to the ECM directly. When the coil switches to Bypass (Open Loop), it's leads are directed from the Ignition Coil Trigger Signal, through the Signal Converter and to the pickup coil only....
* Battery Terminal
* Ground (to ECM)
In other words,
When the module sees five volts at the Bypass pin, it takes the ignition signal from the ECM and uses it to control timing.
If there is not five volts, such as when you are cranking, or have the ESC disconnected, the module ignores the signal from the ECM and does internal timing control.
The 7 pin module has no internal spark advance, and the timing will remain at base in such a condition.
The 8 pin module has some internal advance that kicks in over a certain rpm.
In other words,
If there is not five volts, such as when you are cranking, or have the ESC disconnected, the module ignores the signal from the ECM and does internal timing control....
The 7 pin module has no internal spark advance, and the timing will remain at base in such a condition....
* 4 pin module - electronic ignition, but doesn't do computer timing control, top left
* 7 pin module (large) - electronic module that does timing control, used with coil-in-cap distributors, top right
* 7 pin module (small) - electronic module that does timing control, used with some external coil distributors, bottom right
* 8 pin module - electronic module that does timing control, used with most V8 external coil distributors, bottom left
* 5 pin module - rare and not discussed here. not shown
Might be a matter of naming, but neither of the 7 pin modules on this diagram have internal advance built in. That is only present in the 8 pin module.
just curious but whats the built in curve look like ?
Might be a matter of naming, but neither of the 7 pin modules on this diagram have internal advance built in. That is only present in the 8 pin module....
I am basing my statements off of the experiments of another fello on the board who was running without an ECM and using the HEI moduel. His intent was to run static timing, but he found that the 8 pin module advances on its own after a certain rpm, whereas the older 7 pin doesnt.
If you want I can try to find the thread, it's an oldie.
I am basing my statements off of the experiments of another fello on the board who was running without an ECM and using the HEI moduel. His intent was to run static timing, but he found that the 8 pin module advances on its own after a certain rpm, whereas the older 7 pin doesnt. If you want I can try to find the thread, it's an oldie.
https://www.thirdgen.org/forums/tech...+static+timing
There one talking about the built in advance.
I'll do more searching later.
^ I was just reading that thread you posted, and I agree with RBob that there are many variances with factory settings depending on the distributor, as well as the engine. For instance, w/my current setup (the LG4), when the ECM switches to Open Circuit, base timing is set to zero degrees, w/the carburetor's M/C being set to a 50% duty cycle. In L69 applications though, I believe the simplified settings are a little different, well, base timing would be, actually....
gixxer92
Apr 12, 2022 12:09 AM
MikkoV
Sep 9, 2015 04:25 PM
