bad idle
Old Jun 28, 2008 | 08:38 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
bad idle
car is a 92 camaro 3.1 auto. I dont drive it much anymore. most of the time it sits in the garage. About every 5 starts the engine barely idles. the tach goes up to 3500 rpms and falls back down to like 800 rpms and then back up to 3500 rpms. I turn the car off, wait two seconds and restart and she purs like a kitty. The rotor,car,wires and spark plugs were changed less than 2k miles ago. Any ideas?
Old Jun 30, 2008 | 02:30 PM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
Re: bad idle
I may be a little off, but when my car was having that problem, i changed the MAP sensor, and it idled smoothly, my car tho also would almost die on me when i slowed down too much around cornors, maybe go have it tested?
Old Jun 30, 2008 | 09:49 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: bad idle
Mine used to do that ..I found a bad fuel pressure regulator...was leaking fuel and dumping it into the throttle body..sometimes the car wouldnt start cause it was flooded.If you already checked codes,and basic items and found nothing.I would pull the vacuum line off the reg.and see if fuel comes out.I think regulators and injectors are not high quality on these cars.My reg. was brand new and the diaphram started to leak?.Dont know if the Lucas fuel treatment contributed to the faulty reg. or not but I an't running no more.
Old Jul 1, 2008 | 02:53 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: bad idle
k thanks
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
