temp sender
Old Jul 21, 2008 | 03:19 PM
denthar's Avatar
Car: !985 Chevy Camaro
Engine: 2.8L
temp sender
hey, i just did a cluster swap, and i cant seem to find the temp sender. i drive a 1985 camaro V6 (2.8 mpfi).
Old Jul 21, 2008 | 07:21 PM
scca28's Avatar
Car: 87 Camaro Sport Coupe
Engine: 2.8L
Transmission: 700R4 w/shift kit
Re: temp sender
Hi, if you mean you can't find the part number, I just did this job on my '87 V6 and I used a WELLS TU66 Temp Switch. Or..if you're talking about the physical location for the switch, it replaces the warning light switch located right behind the AC compressor.
After I did the swap I had high temps for a while, and the rad fan would not turn on. After testing the electricals, it turned out I must have had an air pocket in the system in the area of the fan switch at the back of the engine. After several attempts at bleeding the air with the front of the car in the air and the cap off, it finally cleared out. Hope this helps...
Old Jul 23, 2008 | 10:26 AM
denthar's Avatar
Engine: 2.8L
Re: temp sender
i'm still having some trouble finding it. its probly right in front of me. can i maybe get a picture with it pointed out?
Old Jul 23, 2008 | 01:10 PM
scca28's Avatar
Engine: 2.8L
Re: temp sender
This is a shot from my '87, should be the same on your '85. Easier to see if you kneel down close to the fender.
Old Jul 25, 2008 | 03:25 PM
denthar's Avatar
Engine: 2.8L
Re: temp sender
thanks ^-^
sheachopper
Jul 31, 2019 11:27 AM
tommy z-28
Oct 6, 2015 10:58 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
