Fuel Pump Install
Old Jul 27, 2008 | 01:24 PM
RadRacer513's Avatar
Fuel Pump Install
My brother has a 87 2.8 Camaro, with a dead pump. We bought a new one, and want to do the trap-door method instead of dropping the tank completely. Can you do this on the 3rd gens? I know you can on my 4th gen, but wasn't too sure. If so, any write-ups on it? I searched for fuel pump installs and couldn't really find it.
Old Jul 27, 2008 | 01:43 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Fuel Pump Install
Try searching somewhere other than v6, since it's all thirdgen related. And yes, you can. Gotta be real careful if the tank is still in. I found several threads in the Fabrication forum by using "fuel pump access". We typically refer to it as an access panel.
Old Jul 27, 2008 | 05:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I did the access door on my Camaro. Search for some threads as it has been covered many times. IIRC the tank is only like an inch below the sheetmetal so don't puncture it.
Old Jul 27, 2008 | 05:52 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You searched, ehh? Your full of it.....
Here ya go, pics and all....;
https://www.thirdgen.org/forums/tpi/...fuel+door+trap
Old Jul 27, 2008 | 08:12 PM
It never occured to me to search for access panel. I've always heard it referred to as the trap door method; I searched for that and "fuel pump install" and didn't come up with anything.
Anyways, my dad's under the car right now; when I did search for "access panel" I got a lot of posts saying dropping the rear is just as easy, so we went ahead and did it that way.
Old Jul 27, 2008 | 08:17 PM
forkvoid's Avatar
Sure.
Until you have to drop it a second time for a new/different pump. A well-done access panel is a far more efficient use of your time than dropping the rear.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
