2.8L rebuild - does this make sense?
Old Aug 20, 2008 | 11:57 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I've got the engine out of my '89 Firebird and am just getting ready to send out the block and heads...
So, for the re-build, I'm thinking about "waking it up a little bit" but not to hurt driveabilty or fuel economy as it is my daily driver. Do the following mods make sense? (I've already searched the threads and this is my summary)
Port and polish heads and plenum
260 grind cam (with 916 springs and roller-tipped rockers)
Double roller timing chain
Headers
K&N air filter and CAI
Cat back exhaust
Any need to think about different pistons (i.e. forged) or different injectors?
Thanks.
Old Aug 20, 2008 | 12:05 PM
firstfirebird's Avatar
Re: 2.8L rebuild - does this make sense?
Use a 3.1 crank and pistons to up your displacement a little, or use a 3.4 with your intake/exhaust.
Yes your list looks good so far.
Old Aug 20, 2008 | 02:02 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Headers
Cat back exhaust
Thanks.
I'd like to thank you for actually searching. You're one of the more awesome people with questions, because you already searched.
Old Aug 20, 2008 | 04:00 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
That's a good setup. I'm running that same setup right now and so far I like it. I need to go back and fix some things that I may have messed up.
Old Aug 20, 2008 | 09:25 PM
GTA50's Avatar
Thanks for the input.
firstfirebird:
I've thought about using the 3.1 crank and pistons to up the displacement, but I would have to buy them new and I'll have to check on the price. Regarding a 3.4, I thought about that, and actually searched, but in my corner of the universe, they are rare and GM doesn't stock a longblock any more for that size.
But I do have a question, if I was to go with 3.1 pistons (and since I have a set of rings for 2.8 pistons), do the 2.8 piston rings fit a 3.1 piston?
forkvoid:
Thanks for the compliment. Searching the threads is easy (and doesn't cost money) and I have no wish or the money to reinvent the wheel!!
2.8rs:
I'm curious as to the problems you're having. Were they related to the setup or to something else?
Also, one other question, with the 260 grind cam and the 916 springs and roller rockers, do I need to do anything different on hydraulic lifters and pushrods?
Old Aug 26, 2008 | 08:00 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You can't use the 2.8 rings w/ the 3.1 pistons and you can use stock pushrods & (new) lifters w/ the 260 cam.
Old Aug 26, 2008 | 08:40 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
My problems were related to bad valve adjustment on my part. The car runs like a top now. Just use new lifters and you will be fine.
Old Aug 26, 2008 | 09:34 PM
GTA50's Avatar
Thanks guys! I'm replacing the lifters and rods anyway as the engine actually has 425,000+ km on it (doesn't look it thought - regular maintenance and highway miles LOL). I took the block, heads and plenum into the machine shop and lo and behold, he had a 3.1 engine....so, I'm also following firstfirebird's suggestion to use the 3.1 pistons and crank in addition to my first list of mods. The extra cost will be about $300 (parts, balancing, machining, bearings, etc). He also had a 3.4 block but that would have been an extra $900+ - just a little out of my rebuild/overhaul budget.
After this engine is all together, I'll have it dyno'd and see what it ends up with. I'll keep you posted.
Thanks,
Gary.
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 07:57 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BurlyChev
Aug 16, 2015 09:08 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
