quick radiator question....
Old Aug 20, 2008 | 05:26 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
OK, I did a search but didn't really find anything so here goes.
On a 2.8 radiator car, I just installed a TDS wonder bar, and it's great but it smushes my lower radiator hose. I noticed that the temp kinda rises from this.... I found that people just leave it like that but I want to fix it.
I hear the 3.1 lower radiator hose connects to the other side and won't interfere with the wonder bar.
So:
1. Does the lower radiator hose on 3.1 cars connect to the passenger side and not interefere w/ the wonder bar?
2. Aside from hoses, do I need anything else specific to the 3.1 to drop in the radiatopr into my 2.8?
Thanks in advance!
Old Aug 20, 2008 | 06:50 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: quick radiator question....
Here is a pic of my 3.1 with the wonderbar...
Mine had a metal guard under that I just bent up a little to get it in there.
And here is a pic of my new radiator...
...dont mind the measurement lines...
Old Aug 20, 2008 | 08:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I had the same problem. I believe that there is a strap or something that helps to hold the lower hose in place correct? I just either cut that off or shifted the hose. No problems now.
Old Aug 20, 2008 | 09:39 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
Just curious, where did you get your radiator? My is leaking. Beleive it or not, the 4cyl, & 8 cyl. use the same radiator. The 305/350 radiator is on the shelf around here for $100. The 2.8 rad is $150. From my searching, V6 and V8 radiators do not interchange. Is this true? I would love to have the extra cooling from a bigger radiator.
Old Aug 21, 2008 | 04:35 AM
1989karr's Avatar
Engine: 3.4 / 5.0
nice nice thanks for the reply guys!
i might go ahead and swap to a 3.1 radiator and hoses.
sheachopper
Jul 31, 2019 11:27 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
