3.1 wins car show
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Re: 3.1 wins car show
I did a few more changes since this thread and basically just removed some unnecissary emissions stuff. Total here's what I've done to the engine so far: personally ported and polished inside of intake and polished outside, pacesetter headers, dynomax catback exhaust, msd6a ignition, msd blaster coil, taylor 8.2mm wires, ford f1ze injectors, tpis adjustable fuel pressure regulator, 160° thermostat, comp cams magnum steel roller tip rocker arms, and I'm sure there's other things I'm forgetting. I don't have dyno numbers yet because I'm still working on a tune (ecm is pulling timing down to 21° at wot for unknown reasons) but I'm hoping to be at the 200rwhp range when it's narrowed down. Oh, I also do have a ram air box to go with the hood, I'm just waiting on the air filter so I can install it.
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
If you want 200hp at the wheels you're going to have to do some internal work. I don't think its going to be easy, if possible, to do that without working on the heads maybe bumping up the compression...unless you cheat and use NO2.
But either way, good job. How many cars were there?
Engine: 3.1
Axle/Gears: 3.23:1
I don't know exact number and I'm bad at guessing but I would say 70-80 cars??
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
