Idle problems
Old Sep 9, 2008 | 07:10 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
Idle problems
Ok I have been running with out a MAf for just about a year now. The car runs fine when cold but as soon as it gets warm it idles rough like its going to stall but it never does only does this when stopped and in drive or overdrive.
Im getting codes 33 an 34 (no maf) and winaldl has o2 rich constently checked so im guesing it could be the o2 sensor due to the absence of the maf but I thought that when you dont run a maf you automatically go into limp home mode and the ecm dont even check the 02 readings.
Old Oct 27, 2008 | 08:21 PM
frankieboy89's Avatar
Car: 89 rs
Engine: 2.8
Re: Idle problems
Old Oct 28, 2008 | 01:52 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Idle problems
id get a new maf. idle would be better and milage would definatly go up.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
