So close yet so far...
Old Sep 23, 2008 | 06:06 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
In a search for some cheap full length headers I decided to try out some s-10 headers. It came close.
Here's the passenger side.
Looks good, but it made contact here...
and here.
It also didn't come down far enough as you can see here. The far collector is the driver side, which fit better.
Here's the driver side. Almoast a perfect fit. It even cleared the oil filter and oil psi sensors.
Came down far enough as well.
But it was unsettlingly close to the fuel & brake lines.
So the solution would be to move the passenger side down about 2" by straightening out the pipes somewhat and wrapping up the fuel lines with some heat wrap. Break out the torch & some beer.
Old Sep 23, 2008 | 06:32 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: So close yet so far...
I hope for everybody's sake it works out. Just remember to take some pics after the job is done. Make sure you're sober so we can all view them!
Old Sep 23, 2008 | 08:42 PM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
I thought about using the s10 headers looks like they're gunna bottom out a lot good luck with it let us know how ya make out.
Old Sep 23, 2008 | 11:11 PM
bl85c's Avatar
Car: '85 maro
Clearance on the driver side is actually pretty close to where the catcon was, which wasn't great. So yea, it'll bottom out. =P
Old Sep 24, 2008 | 06:46 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Doesn't Pace setter make F-body V6 headers?
Old Sep 24, 2008 | 08:01 AM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
they do but they are more money
Old Sep 24, 2008 | 12:49 PM
In the time and needed materials for the modification would likly cover the cost difference. I don't recall anything from Pace Setter being too expensive.
Old Sep 24, 2008 | 02:12 PM
firstfirebird's Avatar
Long headers? I thought they only made shorties.
Old Sep 24, 2008 | 02:18 PM
project89's Avatar
pacesetter dosent make a long tube for the 3rdgen v6's
Old Sep 27, 2008 | 09:55 PM
bl85c's Avatar
Car: '85 maro
That's why I went with the heddmans. How cheap they were was a nice bonus.
Old Oct 10, 2008 | 12:01 AM
bl85c's Avatar
Car: '85 maro
Well after getting a little happy with the torch and having to patch up a hole I have them in. Gives a nice mellow burble at idle and cruise, but it gets a little raspy up top with nothing but glasspacks on there. If you decide to use these ground clearance is a whopping 4". I bottomed out the first time I took it for a spin . When putting on the driver side header be sure to put the lower rearmost bolt in first, there's barely any room to get it in. I had to take the rest out again the first time I bolted it up to get enough wiggle room.
Old Mar 9, 2012 | 06:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I know I'm bringing this back from the dead, but has anyone tried these with a T-5? S10 headers can be found for a lot cheaper than the PaceSetters, but I don't want to burn up my clutch slave cylinder...
Also, any pics of final mods and clearances?
Old Mar 9, 2012 | 07:33 PM
project89's Avatar
u can wrap the slave cyl with a starter heat blanket, or buy a roll of header wrap and wrap the tubes by the slave cyl and wrap the slave cyl itself
Old Mar 10, 2012 | 12:21 PM
bl85c's Avatar
Car: '85 maro
The t5 is narrower than the th700 I'm sure you'll be fine. You probably want to wrap the brake & fuel lines instead. If you look at the pics you can see where the primaries need to be poped with a hammer to fit. It's pretty obvious what needs to be done when you trial fit them the 1st time.
Old Mar 10, 2012 | 07:30 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Brake and fuel lines are of no concern to me, as I'm bending them myself as opposed to going with the prebent expensive stuff ($55 for a 20' coil and bending it myself sure beats $200!). Prebent doesn't use the external fuel pump I'm planning on, and it's not as pretty as I'd prefer .
I'll get some heat wrap once I get the engine in with the headers and see what's going on down there with the clutch parts and stuff.
:edit: Only problem I saw with the OBX (I guess that's the eBay brand, among others) headers was that they have that crap AIR system with the individual AIR fittings per primary. Going to have to get plugs, I guess.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
