Engine Lethargic, 250 rpm idle, Backfires when revved
Old Mar 10, 2012 | 04:05 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
86 2.8. The tach says it idles at 250 rpm and even if it isn't accurate, the idle is extremely low when it does idle. It revs incredibly slowly, and when I let off the gas it backfires so loud I think my ears will start to bleed. I had a code 42, but I checked the connector on the brown wire on the passenger side firewall and it went away. Occasionally, their is and extra bang in-between the lopes... I hope that last one makes sense. I am at a loss, the timing hasn't been touched since it ran correctly and I just set the fuel pressure. Any ideas?
Old Mar 10, 2012 | 04:23 PM
project89's Avatar
Re: Engine Lethargic, 250 rpm idle, Backfires when revved
is it backfiring out the intake or the ex is the car smoking black?
check the spark plug wires and make sure non are crossed
Old Mar 10, 2012 | 04:40 PM
Car: '86 SC
Engine: 2.8
Out the exhaust, so it's really a misfire? I won't be able to work on it any more today, I have to be at work at six. I didn't think to check the plug wires., but I will first thing tomorrow.
Old Mar 10, 2012 | 11:25 PM
Car: '86 SC
Engine: 2.8
Spark plugs are in the correct order and on the correct terminals on the distributor.
Old Mar 11, 2012 | 11:51 AM
Car: '86 SC
Engine: 2.8
Problem solved, car is running like a champ. It was a mix of a few gas fouled plugs and a couple of bad plug wires. The plugs and wires were fairly new, so i didn't think to check them. Thanks Project for planting the seed in my mind.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
