Question on smog pump hose.
Old Sep 25, 2008 | 06:31 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I'm gonna put on this smog pump because the inspection stations in my area are getting strict on emmission crap. So I decided to get a used pump to put on. I know the little hose goes to my fuel pressure regulator. The middle, if I'm not mistaken goes to the pipe coming from the exhaust manifold area. The large one is the one I can't find a location for. This pump came off a '87 2.8 V6. I gotta 3.1 V6 and I'm stumped. Any photos or ideas?
Ken
Old Sep 25, 2008 | 07:32 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Question on smog pump hose.
There is supposed to be a muffler on the end of the large hose. It dampens the sound of the pump when after the car is warmed up and the air injection is put into bypass mode. You'll need to find one to install or it will be load...and not good loud.
Old Sep 25, 2008 | 07:54 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
That is definatly not the same kind of smog pump I had on my 3.1. let me see if I can find or take any pics of mine.
Here is mine.....
I don't know how much difference it actually is...Its actually not as different as I thought...but it might help.
Old Sep 25, 2008 | 09:07 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
grimmics, you just have a slightly different dump valve. It's the same air pump though.
italiano67
Dec 11, 2016 09:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
