does anyone have this part..
Old Sep 17, 2008 | 03:46 PM
90'bird's Avatar
Car: 1990 firebird
Engine: 3.1L
i need a fuel block seal for my 1990 firebird. i've called everywhere, but all i get told is "discontinued" this is the only thing holding me up from completing what i started. without the seal, i leak fuel which is a big problem.
GM part number 17110853
Old Sep 17, 2008 | 05:01 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: does anyone have this part..
is it an o-ring or gasket?
edit: gmpartsdirect didn't have the item listed...
Old Sep 17, 2008 | 05:29 PM
90'bird's Avatar
Car: 1990 firebird
Engine: 3.1L
its gasket that goes inbetween the fuel block and the fuel rail itself.
Old Sep 17, 2008 | 05:37 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
I'd go to a junkyard and find the best one you can and load it up with RTV.
Old Sep 17, 2008 | 05:38 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
DO you have a picture?
Old Sep 17, 2008 | 05:44 PM
dctrumpet's Avatar
I am not too familiar with the 3.1L, but I do have a friend who has a source for hard to find gaskets, etc.
www.gmpartscheap.com lists the part as a "BLOCK" and sells for ~$43.00. You may try there. Just because they list the part and the price it doesn't mean they have it in stock. It could still be discontinued.
Old Sep 17, 2008 | 05:54 PM
dctrumpet's Avatar
Doesn't the 3.1L have the model 220 TBI? I guess the 3.1L had both tpi and tbi? I just did a quick check.
Old Sep 17, 2008 | 11:04 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Go to your local parts store (Advance Auto, NAPA, your preference) And see if they can get you a roll of gasket material, you would probably need rubber. Use a razor blade and trace it out yourself.
I'm assuming though that this is a flat gasket?
Old Sep 18, 2008 | 08:23 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Eh? The 2.8/3.1 is MPFI.
Old Sep 19, 2008 | 01:55 PM
dctrumpet's Avatar
Sent several PM's to you.
That part number is a service kit. It came with the block, seal and screws. I have a diagram of it and I will try to match it with my GM gasket catalog.
Let me know asap.
Old Sep 19, 2008 | 02:50 PM
dctrumpet's Avatar
Is this it? It's a poor quality image, but it should do the job, lol.
Old Sep 19, 2008 | 05:59 PM
90'bird's Avatar
Car: 1990 firebird
Engine: 3.1L
yup, thats exactly it. thats all i need to get things going. sure i can get the car running, i just don't feel like leaking fuel when i go to drive around lol.
Old Sep 25, 2008 | 08:50 PM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
where are you located if not far from sunbury i have a complete rail the injectors on it are junk but the rail is in great shape if your intrested i could part with it for what its worth to you
where are you located is a dumb question if you pay shipping on it ill hook you up pm me if your interested
Last edited by badpontiac; Sep 25, 2008 at 08:52 PM. Reason: Automerged Doublepost
Old Sep 26, 2008 | 12:00 AM
90'bird's Avatar
Car: 1990 firebird
Engine: 3.1L
oh, forgot to update this thing..heh. i got in contact with a relative further south of me. he is into car restoration and has the proper connections to get these kind of things. i installed it, car runs like a dream. only problem i have now, is i have an air leak somewhere, but that shouldn't be too hard to take care of i hope.
Old Sep 26, 2008 | 04:47 PM
90'bird's Avatar
Car: 1990 firebird
Engine: 3.1L
i know double posts are frowned upon, but i am curious if anyone knows the bolt measurements for the fuel rail mounting bolts. everything is in running order, i just got a small fuel leak from the injectors not staying in place without the bolts. its so nice to finally have my car back after almost 4 months of not driving it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
w0lfpack91
Apr 16, 2015 09:16 PM
Zink57
Aftermarket Vendor Review
16
Mar 28, 2015 06:08 AM
Dutch420
Aug 15, 2014 08:45 PM
