1988 camaro
1988 camaro
i just bought a 1988 camaro rs with a v6 (2.8) it pretty banged up but i cant get it started 4 some reason there is no fuel getting to the motor is there anything i could check before i change the fuel pump
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: 1988 camaro
fuel pump relay, fuel filter, make sure you have gas, make sure it has proper voltage to run the fuel pump.
Car: 1982 Camaro
Engine: 2.8L
Transmission: automatic
Axle/Gears: stock
Re: 1988 camaro
try kicking the bottom of the gas tank or hitting it with a hammer/mallet. You may be able to get the fuel pump to work again. Might not be for long, but it'd be long enough to see if the engine will start
