1990 3.8L V6 GN powered Firebird! Pics!!
Old Sep 29, 2008 | 09:25 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Well, I finally got my Third Gen Firebird running again after a round of mods and some preventive maintenance. The previous combo netted me a best of a 12.20@113mph with a 1.75 60'. I had so many issues too(tuning, boost and exhaust leaks, lifting heads, 8* knock retard) ANyways, hopefully I have most of them ironed out!
I recently installed:
AlkyControl Single nozzle methanol injection kit
3 bar MAP sensor
RJC Power plate(air distribution plate for better burn)
Modified Duttweiler Intercooler neck(more cfm)
Walbro 340 in tank fuel pump(preventive maintenance)
TurboTweak Alky chip(23/21* timing @ 24-26psi boost)
Accel 42,000 volt coil pack(mine broke)
New SCE copper exhaust & turbo flange gaskets
SLP Line lock kit
Fel-pro intake gasket set
Felpro 9441HT Head gaskets(had N/A gaskets on before and was lifting heads)
new motor mounts
new delco starter
NGK UR6 plugs gapped @ .032"
re-wrapped the 3" downpipe
I removed the exhaust manifolds due to numerous cracks and warps on both sides. I machined the surfaces smooth and installed copper manifold gaskets as well as new turbo gasket. Every exhaust gasket on the car wasnt sealing, had 2 or three cracks in the stock 1987 manifolds(stainless steel).
This car has been a rollercoaster of a project, plenty of highs and plenty of lows. Hopefully, itll make it out to the dragstrip before the end of the season!! Hope ya'll like, I know I do!!!
One head torqued down w/ ARP bolts
Got the Turbo mounted and top end done
3" Downpipe w/ old school HKS Wastegate, before heat wrap(20psi spring)
Intercooler mounted
Final(for now) product
Old Sep 29, 2008 | 10:28 PM
project89's Avatar
Re: 1990 3.8L V6 GN powered Firebird! Pics!!
i have a friend who works on gn's he gave up using gaskets,said they always blow out.
try coating them with copper seal, or u can try just coating the mating surfaces with antiseize
Old Sep 30, 2008 | 07:11 AM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
that is awesome!!
Old Oct 2, 2008 | 11:29 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Sweet. Are you going to make a tta clone?
Old Oct 4, 2008 | 07:56 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Looks similar to a guy around the corner to me.he has an 88 Iroc that came with 350.He had it modded like crazy and only got best of 12.20`s no matter what he did.Swapped to GN turbo v6 now it`s knocking down low 10`s consistantly.Got me thinkin about starting another project.Good luck.He has the intake ducts going down in front of the radiator like the stock Iroc but much larger.I`ll try to post some pics if you want.Best thing he says is its crazy streetable at almost 30 mpg highway and goes around town like a little v6 and kills prettymuch anything else atreetable.
Djmathis123
Sep 29, 2015 01:36 AM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Dialed_In
Aug 20, 2015 01:45 PM
