questions about idle
Old Oct 2, 2008 | 08:22 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
Hey, I noticed that when the outside temps are around 40 degs my motor will run really smooth. It seems to pull harder and better throttle response. I know that cooler air will help a car run faster but what could be causing the car to idle rougher when it gets warm.
How can I test the O2 sensor so that I am not buying an new one if it's not needed. The timing is set at 11 deg btdc. I am now getting atleast 260 miles on a tank of gas. Are these tanks 14 gals, if they are then I could go about 20 more miles cause I usually put about 13 gals everytime I fill up.
My car idles fine when it gets warm, no reving up or down at anytime. The motor just runs kinda rough, At idle it is like my old v8. The car shakes. I've checked my vacume lines and they seem to be fine. What if I take the egr and solenoid off will it run any better? I do not have a regs were I live.
Thanks for your help.
Old Oct 5, 2008 | 08:41 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
Re: questions about idle
i think the tancks are 15.5 gal but i just wanna know how ur getting 260 miles a tank im only getting 150 at the most with mine and i drive people nuts driving down the road idle........ and if im in a 35zone i get it up to 41 so it locks up
Old Oct 5, 2008 | 10:16 PM
micali's Avatar
Engine: 2.8
Not quite sure about your question but I don't really know how it is but it is. I've cleaned the throttle body really good, used seafoam in it and drive it hard sometimes but for the most part I take it easy. I need to replace the plugs and see if that helps my roughness. What do you mean it locks up?
Old Oct 11, 2008 | 09:33 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Hey man it may just be your o2 since it starts running rough when its warmed up. No doubt it is gonna be slower when warm. But o2 should help and i think they are only like $25 at autozone, but i could be mistaken.
Old Oct 11, 2008 | 02:42 PM
micali's Avatar
Engine: 2.8
That's the next thing I was going to replace. I figured it was probably about time to replace it anyway. thanks
Old Oct 19, 2008 | 06:40 AM
Dufangoer's Avatar
hi
just my two centsbumpcheap wow power leveling --------------------------------buy eq2 plat, eq2 gold, everquest platinum, rs gold, silkroad gold,
Old Oct 19, 2008 | 01:32 PM
micali's Avatar
Engine: 2.8
Don't post crap like that none of us are interested in your nerd games. IF you got something to help with then post otherwise keep that crap to yourself.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
