fuel pump issue
Old Oct 15, 2008 | 09:27 PM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
fuel pump issue
Good evening, have a 87 camaro and the fuel pump just died at 240k.
Good life I guess, well I have a Holley 255 intank pump from my 91 RS, which was changed out with a aeromotive pump.......Should I go and buy the OEM pump for the V6, bout a $100, or will the holley work and not give me any problems? Whats the dif in psi or is there anyfor the V6/V8.....this is a MPFI 3.4(changed the 2.8 out).
Old Oct 16, 2008 | 06:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: fuel pump issue
Any excess fuel will be released by the fuel pressure regulator back into the tank, unless you're also running returnless, in which case you might have a problem, but you're not, so you're good, right?
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
