87 2.8 help please
Old Oct 14, 2008 | 08:00 PM
87project's Avatar
87 2.8 help please
i have a 87 camaro 2.8 i rebuilt the motor becasue i blew it up. i put a new crank in it couldnt be cut down i tore it up too much so i have another crank i put new bearings, oil pump, rings the whole deal and i hand lapped the valves and new valve seals. my problem is that i have it in the car and everything hooked up and dropped the distributer in on top dead center and it will turn over and everything i have fuel i have spark but the thing just wont start. my plugs are gapped right my wires are on right. i put new dizzy modulator and new coil on. i have run out of ideas the only thing i can think of is that there might be a different way to drop in the dizzy then what i did any help would be great thanks
Old Oct 15, 2008 | 08:38 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 87 2.8 help please
set the timing 10 degrees btdc and check the injectors. 2.8's don't like starting with out the timing set right. looks like u have to pull the distributor again.
Old Oct 15, 2008 | 09:45 PM
87project's Avatar
thanks i have checked the injectors and they are pulseing. you said to put it at 10 degrees but where do i have the rotor point at number one still? i just read in my book that the rotor should between 1 and 6 and i had it pointing at number one not in the middle.
Old Oct 16, 2008 | 02:05 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
sounds like you are 1 tooth off.
Old Oct 17, 2008 | 08:33 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
I had this same problem a while back and I was 1 tooth off on the dyzzy.
Last edited by 84olmpcboy; Oct 17, 2008 at 08:39 PM. Reason: Automerged Doublepost
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
