Fuel System problem, please help!
Old Oct 28, 2008 | 04:06 PM
Bricktop12000's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
I have a 1992 Camaro RS that I pulled out of a back yard that has been sitting for 4-5 years. Im not getting any power to the fuel pump relay. I jumped the power wires while the relay was hooked up and the pump spins. Looking at the wiring diagram for the engine control system it says that there is an in line fuse for this sytem and it is fuse no. 3, 20 amp. Dose anyone know where this inline fuse may be located? I have already dropped the tank and replaced the pump, strainer, and pump pulsator. I pulled a tank out of a 91 because everything in the tank and the tank itself was coasted in like an inch of varnish.
Old Oct 28, 2008 | 04:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel System problem, please help!
If I remember correctly, the inline fuse is under the hood, passenger side, along the fender/hood line. If you look at where the air cleaner is (round cannister) on the radiator support is a terminal block.
From that block is a wire that runs along the passenger fender line. The fuse is in a small rubber boot like thing inline with that wire. It may actually be close to where the air cleaner is.
RBob.
Old Oct 28, 2008 | 07:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
RBob.
The fuse has 2 wires running in to it, obviously. One is red and the other is orange. I don't know if you will have another one next to it or not, but that's how you can tell the inline fuse that also runs the ECM constant power...
Old Oct 30, 2008 | 11:20 AM
Car: 1992 Camaro RS
Engine: 3.1 V6
Axle/Gears: Stock
Thanks for the help. The info that yall gave me solved my problem. the power of the web!!!!
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
