2.8 valve lash adjustment please help
Old Dec 30, 2008 | 02:06 AM
89rs2.85speed's Avatar
ok so i just spent a few hours trying to figure out how to adjust my valve last due to had to take out the push rods to change intake gasket i read the haynes book and a few thread on here but still unsure on how to find zero lash to make the final preload adjustments
i understand that you start at the number one cyllinder making sure its at tdc which i set before taking the pushrods out my qestion is whats the best way to find zero lash
thanks a bunch
Old Dec 30, 2008 | 08:52 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 2.8 valve lash adjustment please help
zero lash is where the pushrod does not move up and down. you can feel slight drag when turning the push rod.
Old Dec 30, 2008 | 10:35 AM
ok whats the best way to get to that point i heard turning or moving the push rod up and down while tighting i also heard use a feeler gauge or dial im just trying to find the best way
Old Dec 30, 2008 | 11:56 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
i personally keep turning the pushrod untill it starts to drag as your tightening up the rocker, that will mean there should be no up down movement, then apply 1/2 turn extra tightening the rocker down.
i take it haynes gives you the order in which ones to tighten whilst no.1 is TDC and so on.
Old Dec 31, 2008 | 11:57 PM
Dakine858's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
thanks a bunch
Hand crank the engine until the mark on the damper is aligned with TDC mark (No. 1 cylinder firing position). Once the engine is properly rotated and you're sure that the number 1 cylinder is in firing position, adjust these valves: Exhaust - 1,2,3; Intake - 1,5,6. To adjust the valves, back off the adjusting nut until lash is felt at the push rod, then tighten the adjusting nut until all lash is removed. You can do this by rotating the push rod while tightening the adjusting nut. When all lash has been eliminated, turn the adjusting nut an additional 1 and a half turns.
Crank the engine one revolution until the mark on the damper and TDC mark line up again. The engine should be in the No. 4 cylinder firing position. Now you can adjust the following valves: Exhaust - 4,5,6; Intake - 2,3,4. When your finished, start up the engine and set the timing & idle speed
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
