Does the cam make a sound?
Old Jan 1, 2009 | 04:50 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I was checking my pulleys today by removing the serpentine belt and spinning them by hand. While they all seemed ok, I started my engine up. I noticed the pulley for the cam was making a kind of medium "chugging" sound. Is this normal or is something amiss? Timing chain perhaps?
Ken
Old Jan 1, 2009 | 05:25 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Does the cam make a sound?
Pardon my dumb question, but...
Which pulley are you referring to as the "cam" pulley? You might also want to elaborate on this "chugging" sound. Like, compare it to something that we've all heard.
Max,
Old Jan 1, 2009 | 06:08 PM
ken3983's Avatar
Well the pulley I'm talking about is the one right there at timing marks. The one on the very bottom of the engine. The sound is more like an small exhaust leak. Kinda a hollow sound.
Ken
Old Jan 1, 2009 | 06:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
that would be your crankshaft pulley.
Old Jan 1, 2009 | 06:54 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Depending on the noise which will be hard for any of us to really fully know it could be the plastic timing chain guide.
On my 3.1 I had that guide break which is right behind the timing chain cover around the area your talking about. It sounded bad and might go with the sound your refering to.
Old Jan 1, 2009 | 07:02 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
^if thats the case get a new timing chain while your at it. thats what happened to my cars original engine. it wore off the damper at first then skipped timing.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
