Starts everytime....but it just won't idle.
I have an 89 RS with a 2.8L (fuel injected). I never had a problem with it until a week after I decided to sell it. Everytime I start it I have to keep giving it gas or else it just dies. My first instinct told me it was the fuel filter. After I changed the fuel filter it was apparent that the old one was all clogged up. So, I thought for sure I fixed it. I started it up again and it did the same thing as before. I drove it around the block thinking that I just needed to get fuel circulating, but it ran kind of rough and just kept dying. It started up everytime with no problem. It just won't idle.
Any suggestions would be greatly appreciated.
Thanks!
P.S. How do I pull a code? Isn't there a paper clip trick?
Thanks!
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: Starts everytime....but it just won't idle.
Sounds like a vacuum leak. Also, any codes?
I would suggest you check all of the plastic lines around the engine - they become very brittle with age. Also, how many miles on the car? After 20 odd years, the original gaskets will also tend to fail and leaks around the intake will become evident.
Hope that helps.
Hope that helps.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Sounds to me like an idle air control valve. swap that out with a new one, and you should be fine.
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
pulling codes: find the ALDL diagnostics port. if your sitting in the drivers seat its below the dash on the right hand side. it looks like a connector but not connected to anything. one end of the paperclip or wire in the top right terminal and the other end the next terminal to the left. the computer will flash a code twelve in a sequence ( flash, pause, flash-fash, pause) any other codes in the ecm will be flashed in a similar sequence. longer pauses in between codes.
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Axle/Gears: ?
sounds kinda similar to a problem i had... check the throttle body to intake gasket. replaced gasket and cleaned iac passage. idles like a charm now.
part of the gasket was gone. huge air leak.
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
sounds like a vacuum/gasket leak...
while the engine is running, get out and get under the hood and listen for hissing... could be the iac... but that's not what it sounds like to me...
just my 2 cents
just my 2 cents
