problem
Old Jan 22, 2009 | 03:58 AM
magzbro92's Avatar
problem
about a week and a half ago, i bought my first car, a 1985 2.9L Camaro with a great body, but a wierd motor. The motor has so many non camaro parts I cant tell Camaro from non-Camaro. Anyway, my problem is that when i push down on the gas, it doesn't want to go, and you have to just about push the pedal to the floor to get it to go. Besides not having a muffler, I haven't been able to "find" any problems, like vaccum leaks. I've put new plugs distributor, and wires on. I haven't checked the fuel pump yet, i plan on doing that tomorrow, but besides that does anybody have an idea what else could cause it to do this?
Old Jan 22, 2009 | 10:54 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: problem
Welcome, first off you have a 2.8, not a 2.9... maybe that was a typo. What do you mean by non-camaro parts? your issue may be that the catalytic convertor is plugged up. Check into that first.
Old Jan 22, 2009 | 01:30 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: problem
I'm also curious about this. Take a picture and post it up.
Old Jan 22, 2009 | 03:05 PM
crmmaj9's Avatar
Car: 1990 Chevy Camaro
Engine: 305 TBI
Re: problem
Also try the TPS throttle positioning sensor. Good luck!!!
Old Jan 24, 2009 | 04:19 PM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Re: problem
run some injector cleaner through it yet?
yes, pictures...
Old Jan 27, 2009 | 04:16 PM
bkenealy's Avatar
Re: problem
well i have the exact same car. but i would defintely check the throttle cable. i had problems with my car with that and i tightened it up and right away she worked.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
