Code 33 and code 34... sporadic.
Old Feb 12, 2009 | 12:38 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
So, sometimes I'll be driving around for days and have no codes. Other times, I'll drive around with a code for days.
When I check it, I have a 33 and 34 (car is 2.8 MPFI 1986) So, as I understand, I've got a 33 MAF code... and a 34 MAF code. My MAF has been replaced with a new one, that was months ago, and yet, I still get the codes sometimes. When I do have them, my car runs differently. I could floor the gas and there would be a much longer delay than usual for it to kick in, and if I let go of the gas any time, there is a delay for it to cut out. And when it does, you can really feel it just drop all of a sudden.
I have an Air/Fuel ratio gauge hooked up inside (No, I'm not running a turbo) and it also reads differently when I have the codes. It'll be completely lean when I'm on the gas, and stay in one spot. When I let go, it jumps to the opposite side, rich, and then goes back after a second.
If the code isn't showing and the car seems to be running fine, there is much more of a transition between the rich and lean, and it doesn't just stick in one spot or the other...
Any ideas/opinions are appreciated
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
