Which Heated O2 With Pacesetters????
Old Feb 17, 2009 | 02:11 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
I have the problem of running rich with the pacesetter headers and I'm wondering which O2 sensor to run on it? Thanks.
Old Feb 17, 2009 | 02:34 PM
project89's Avatar
Re: Which Heated O2 With Pacesetters????
any heated o2 sensor will work, 3 or 4 wire, bocsh makes universal ones that dont come with a conector on the wires, get one of those, since ur only gonna be cutting the conector off anyway.
i belive i have a part number posted in the turbo sticky on the top of the forums
Old Feb 17, 2009 | 02:38 PM
project89's Avatar
i have a walker o2 part number that i posted in the sticky
dont have the bochs part number though but any parts store can cross refence it
walker 3 wire o2 PART NUMBER 250-23003 cost was about 55$'s
Old Feb 17, 2009 | 03:23 PM
Car: '89 IROC-Z
Engine: LSx
Thanks alot, also does the 3 wire harness adapter GM makes work for the 6's? If not any suggestions on retro-fitting?
Old Feb 17, 2009 | 03:26 PM
project89's Avatar
i just cut and spliced mine and soldered the connections.
ur gonna have to run ur own power and ground to the sensor anyway
u could always goto the junkyard and pick up a pigtial off a car so u can still have a connector on it
Old Feb 17, 2009 | 03:32 PM
Car: '89 IROC-Z
Engine: LSx
Okay, cutting and splicing is going to be the easy way for me, thanks for the info.
Old Feb 18, 2009 | 02:07 AM
Car: '89 IROC-Z
Engine: LSx
Dave, you wouldnt happen to have a picture of the walker installed? Or know which wires are what color as far as connection to harness, ground, and power? Amazon had 2 of these left in stock for $10 so I grabbed one.
Old Feb 18, 2009 | 11:32 AM
project89's Avatar
should be 2 black wires and one blue wire iirc
the blue wire should be the signal wire
on the walker o2
i think on the bocsh the signal wire is grey with 2 black wires
ill dbl check for ya tom though
Reni-Camaro
Mar 14, 2012 03:50 AM
yellowmaro
Sep 23, 2010 03:32 PM
rsrsrs
Feb 3, 2009 11:06 AM
