'87 Crankshaft Casting #
Old Mar 7, 2009 | 10:38 AM
87InRecovery's Avatar
Car: '87 Camaro Sport
Engine: 3.4L w/headers, Crower & Hypertech
Transmission: 700R4, B&M Shift Kit
Axle/Gears: ?
Have my '87 V6 that requires a new crankshaft. Eagle makes it new, and it is offered through Summit. The only thing is that it stated it is for replacement "crank #817".
I THINK my crank says 991, but I am not positive. Anybody know if the #817 crank will fit and function properly, or does modifications have to be made? It also says "external balanced" for the Eagle crank.
Summit:
Eagle Specialty Products 10173817
Old Mar 7, 2009 | 11:47 AM
firstfirebird's Avatar
Re: '87 Crankshaft Casting #
187 is the 3.1 crank with 3.307" throw. If you use a 3.1 crank in your 2.8, you will need 3.1 pistons, and you will now have a 3.1
Old Mar 7, 2009 | 12:01 PM
Axle/Gears: ?
So, the #187 is a 3.1L's crankshaft then. More or less, it is creating a stroker if I was going to purchase it? I imagine that this would use shorter pistons??
Everything else is the same then, inlcuding the piston traveling order; don't need one piston going up when it should be going down.
Old Mar 7, 2009 | 05:36 PM
The wristpins were moved in the 3.1 pistons, same firing order, same rods.
Yes, you are creating a "stroker"
Old Mar 8, 2009 | 08:17 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Are only the 3.1 pistons required (w/ the crank) to create a stroker?
Old Mar 8, 2009 | 08:22 PM
Yessir
Old Mar 8, 2009 | 08:28 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Is it worth spending money on it, like what kind of gains do you get? What size pistons do I get?
Old Mar 21, 2009 | 06:58 PM
Axle/Gears: ?
Alright, I have the #817 crank ordered, along with the 3.1L pistons!!!! This will complete the engine build internally.
Being that I am changing this crankshaft out and will have it all internally balanced, what Harmonic Balancer do I purchase??? What about the Flexplate???
Old Mar 22, 2009 | 09:40 AM
I'm such an id10t!
I transposed the casting numbers.
189 is the 3.307" stroke, 187 is the 2.99" stroke.
IF the crank you bought is a forging, it seems really low on cost.
If it is fact a forging, keep the crank and exchange the pistons for 2.8 pistons, if it is a stock nodular iron crank, I would call and change the crank to 3.1.
db057
Apr 28, 2019 07:45 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
